Old 07-09-2024, 10:29 AM   #1
1931 flamingo
1931 flamingo's Avatar
Default Needed
I'm in dire need of a 46-48 generator armature (my re-builder can't get one),
other years might work(?).
Thanks in advance.
Paul in CT
Old 07-09-2024, 10:45 AM   #2
rockfla
rockfla's Avatar
Default Re: Needed
Try Steve Blancard here on the Barn he goes by ndnchf OR where it me I would send HIM your generator and let him rebuild it for you....NONE better than him and his work!!!! He is "TOP NOTCH". It will be better than when it was new and 100% concours. You can youtube his videos he had done on a few generators and his quality of work and upgraded bearings as well as he has posted both pictures and links to his work here on the barn!!!
https://www.fordbarn.com/forum/showthread.php?t=339681
https://www.fordbarn.com/forum/showthread.php?t=339680
Old 07-09-2024, 04:30 PM   #3
1931 flamingo
Default Re: Needed
to the top
Old 07-10-2024, 07:06 AM   #4
rockfla
rockfla's Avatar
Default Re: Needed
Check with Fred at Southside Obsolete
Old 07-10-2024, 07:23 AM   #5
deuce lover
deuce lover's Avatar
Default Re: Needed
Will this work?
https://www.ebay.com/itm/387039447950
deuce lover is offline   Reply With Quote
Old 07-10-2024, 10:05 AM   #6
1931 flamingo
Default Re: Needed
I'll try it. Thanks.
Paul in CT
Old 07-10-2024, 10:39 AM   #7
1931 flamingo
Default Re: Needed
Just ordered it ! ! Thanks again.
Old 07-11-2024, 05:37 AM   #8
ndnchf
ndnchf's Avatar
Default Re: Needed
Glad you found one. If I can be of any assistance, let me know.
Rockfla - thanks for the kind words and recommendation.
Steve Blancard
ndnchf is offline   Reply With Quote
Old 07-11-2024, 07:00 AM   #9
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Needed
I would expect the original 46-48 armature to have a groove at the end of the threads for the clip that prevents the threaded pulley from unscrewing.
the ones without the groove were for pulleys held on with a nut
