Old 06-20-2024, 11:24 AM   #1
Canton_Model_A's
Canton_Model_A's's Avatar
Question 12v Converted 1929 'A'
Folks:
I have a converted 1929 'A' over to 12v negative ground. after doing some work on it with other 'odd' issues, I have seen thru the suppliers that they sell a coil that doesn't require the ballast resistor. I had issues when I was bringing it out of storage and had already replaced the coil as it wasn't getting spark thinking that was the issue. Turned out the ammeter was faulty.
I am trying to re-wire it back to as much stock as I can, I have installed a brand new wiring harness and it has the 12v alternator. why would I require the Ballast resistor in the loop or can I use the resistor-less coil from the suppliers.
ps.
I did NOT do the conversion to 12v so I don't even know what is involved with that conversion.
1929 Model A Tudor - "Darla"
'29 Model A: Old enough to start with a crank, young enough to steal the show!
"Stay away from negative people, they have a problem for every solution"
Model A Ford Club of America
Model A Restorers Club
Motor City A's Club
Canton_Model_A's is offline   Reply With Quote
