CONTINUED FROM THREAD -
https://www.fordbarn.com/forum/showt...98#post2318698
Originally Posted by Randy Knight
I bought a replacement top cover as the original has a couple of dents in it. Is there a way to use the new cover with a paper filter with the existing base?
This is for a 55 T-bird.
The easiest way (IMO) is -
https://www.classictbird.com/Dry-Ele...ctinfo/9601XK/
To modify any other way is destroying the OEM ACL ASSEMBLY ($$$) (and again IMO).
The 1955 and 1956 ACL bases are different as to allow for the 1956 4000 choke housing clearance. If this kit is used on a 1956 ACL BASE, the ACL FILTER ELEMENT will become misshapen-ed.
http://nebraskalandtbirds.org/sitebu...conversion.pdf
The larger the filter element, the less restriction on air flow.
