Old 06-04-2024, 02:49 PM   #1
Rodrelic
Default Blue Crown cross ref?
I have Blue Crown 00 plugs, does anyone know if it is compatible with A or T?
Rodrelic is offline   Reply With Quote
Old 06-04-2024, 03:34 PM   #2
nkaminar
nkaminar's Avatar
Default Re: Blue Crown cross ref?
That would screw into the head but the question would be if it has the right heat range. You could try them and then read the plugs to see if they are right for you engine.
Old 06-04-2024, 05:22 PM   #3
J Franklin
J Franklin's Avatar
Your plug has a short reach compared to a model A plug.
Old 06-04-2024, 05:24 PM   #4
Y-Blockhead
Y-Blockhead's Avatar
Exactly what I was thinking...
Old 06-04-2024, 05:39 PM   #5
WHN
They wii foul out within 10 miles or so.
WHN is offline   Reply With Quote
Old 06-04-2024, 07:20 PM   #6
Rodrelic
OK, thanks, maybe for an air cooled motor
Old 06-04-2024, 07:23 PM   #7
stevests
stevests's Avatar
Model T's use a 1/2" pipe thread plug - no gasket.
stevests is offline   Reply With Quote
