#1 |
Another rivet question….
I’m assuming there is a set of tools used o install the crank hole cover rivet. Anyone know the type/size? Thanks! |
#2 | |
![]() Quote:
The issue generally is unless the rivet is set uniformly around the edges, the crank hole cover will either be too stiff to turn, -or it will rattle from being loose. |
#3 |
My crank hole cover was very loose too. I have some split rivets that I used to replace the loose ones. Worked great except that they are tight, and they are stainless. PM me and I will take a pic.
#4 |
I had a loose cover and I fixed it - at least for now - using a small o-ring. Took some work to wedge the ring under the rivet edges on the back of the shell, but it’s holding for the moment.
#5 |
A method to reduce the precision required is to use one of those spring washers. There are two types, conical and the ones that look like a potato chip.
#6 |
No special tools are necessary. Use a proper sized drill to drill a divit into a block of steel or similar and hold in a vice. Use a round, pointed chisel to spread the rivet end and finish with a flat drift. Use tape on the rivet head during this process if you do not want to mar the finish. |
#7 |
Thanks. The tool isn’t cheap, but this won’t be my last “A” either. Maybe. Ican do a few for people and recover some costs. Looks like it’ll do some other rivet jobs like the hood leather corners, etc.
#8 |
Thanks Steve. I’ll experiment with that technique too
#9 |
Tube rivet sets are available in different shank diameters but they require care in the bucking process.
