Old 05-26-2024, 02:38 PM   #1
Kube
Kube's Avatar
Default light switch install
Hello men!
Might seem simple to you but I'm kinda a newbie to the Model a world so here goes...
The piece on the end of the horn rod (picture attached) ... gets installed at the 3 and 9 o'clock position or the 12 and 6 o'clock position?
Methinks the 12 and 6 but not certain so the question.
yes, horn rod is set on steering wheel with lever at 6 o'clock and yes, steering wheel is in the middle of its full travel.
Thanks in advance
Old 05-26-2024, 02:41 PM   #2
Chuck Dempsey
Chuck Dempsey's Avatar
Default Re: light switch install
You thinks correctly, 12 - 6.
Chuck Dempsey is offline   Reply With Quote
Old 05-26-2024, 02:46 PM   #3
nkaminar
nkaminar's Avatar
You could install it at the 3-9 position but then the light switch at the steering wheel would be at 3 or 9 o'clock.
Old 05-26-2024, 04:36 PM   #4
Kube
Kube's Avatar
For once methinks correctly!
Thank you kindly.
Old 05-26-2024, 04:53 PM   #5
Wick
Wick's Avatar
Go to Hookemfair Garage on YouTube. I show the process of installing the light switch.
Wick is offline   Reply With Quote
