Old 05-16-2024, 10:36 AM   #1
richard crow
Default 97 carb on a 51 8ba
has any one put a stromberg 97 carb on a 51 8ba eng. & kept the orignal dist taking the vacuum from the intake manfold. how did it run
richard crow is offline   Reply With Quote
Old 05-16-2024, 10:53 AM   #2
tubman
tubman's Avatar
Default Re: 97 carb on a 51 8ba
Nope; never saw the point of it. I remember that my older brother did it on our '51 Fordor back in the fifties and replaced it within a week.
One caveat : I have heard that back then "Western Auto" and others sold a version of the 97 with the proper vacuum plumbing for a Load-a-Matic, but I've never seen one.
Old 05-16-2024, 11:15 AM   #3
Tim Ayers
Tubman:
I was also going to mention the same variation of the 97 with the vacuum port in the base. I've only seen a few from all the years going to Hershey, but its possible that a carb guy/rebuilder may have one in their stash.
Old 05-16-2024, 11:33 AM   #4
tubman
tubman's Avatar
While the 97 does flow a bit more (162 cfm vs 155 cfm) due to slightly larger venturi's, more improvement could be had by using a later "Y-Block" Holley (185 cfm) that is still compatible with the "Load-A-Matic".
Old 05-16-2024, 02:07 PM   #5
Roger W Gerow
The Y block carb has a 1 1/16th venturi. One has been installed on my 1951 8BA. I notice a little bit better acceleration when going through the gears.
DD658
Roger W Gerow is offline   Reply With Quote
Old 05-17-2024, 08:28 AM   #6
Chris Marshall
Chris Marshall's Avatar
I have a NOS Stromberg 97 designed as a replacement for the 49-53 Fords with the loadamatic distributor. The original box is a bit rough, but all the documentation is with it. Also have a NOS Carter replacement carb for 34-53 (per the instructions) flathead Fords. It has the loadamatic port also. Pics of the 97:
Chris Marshall is offline   Reply With Quote
Old 05-17-2024, 11:51 AM   #7
petehoovie
petehoovie's Avatar
