05-14-2024, 02:35 PM | #1 |
Where Alum Cam Gear?
I need to buy an aluminum cam gear for an 8BA with a Max 1. Is one better than another and is there a good place to buy? I am used to buying Model A parts, I’m new to V8’s
05-14-2024, 03:25 PM | #2 |
Re: Where Alum Cam Gear?
Aluminum 8BA cam gears are easy to get many vendors offer them for sale. Overall all 8BA aluminum gears are the same so any vendor you use to buy a gear the one you get will work fine.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
05-14-2024, 03:26 PM | #3 |
go to barnfind, Fred ,southside obsolete, best place to start.
05-14-2024, 03:53 PM | #4 |
This is about as inexpensive as I could find. You might also want to check with 3rd Gen Automotive.
https://reds-vintage-parts.com/store...-for-1949-1953 |
05-14-2024, 04:00 PM | #5 | |
Flathead Ford New Camshaft Gear, aluminum bolt on for 1949 - 1953
