Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 04-30-2024, 09:26 PM   #1
dirtywaterdiver
Default Pinion angle question
So, I have an engine angle of zero° and a rear end angle of 4°. I understand between zero and 3° is ideal for drive shaft angle. I can't for the life of me figure out how to change the trans end since there is no play in the motor mounts, but I can add an angled shim to the rear end under the leaf springs. What would be the correct fix?
dirtywaterdiver is offline   Reply With Quote
