Old 04-28-2024, 09:17 PM   #1
1912Krit
Default Rear spring shackle installation
Gentlemen:
I am having trouble lining up the spring and perch to insert the rear shackles.
I have the passengers side (right side) almost in but the rear end seems to be cocked at an angle. Photo shows how drivers side isn't lined up and the distance the spring still has to go.
It looks like I still have a ways to go spreading the spring, but the spreader is getting very tight. If I keep going will the rear end shift into place? Of course it is just connected at the universal. Or should I just try to start over again?
Thanks,
Don
1912Krit is offline   Reply With Quote
Old 04-28-2024, 09:29 PM   #2
mass A man
mass A man's Avatar
Default Re: Rear spring shackle installation
I think you may have more luck with a "full-length" spreader bar. Are you using one of the "short" type spreader tools?
mass A man is offline   Reply With Quote
Old 04-28-2024, 09:49 PM   #3
1912Krit
I am using the spreader that goes the length of the spring. I guess I am just getting a bit nervous because of the tension and that the rear end is cocked a little. Photo is of the passengers side where I was able to get the shackle in almost all the way
Old 04-29-2024, 10:13 AM   #4
1931 flamingo
1931 flamingo's Avatar
Try realigning the rear end.
Paul in CT
Old 04-29-2024, 10:43 AM   #5
1912Krit
Do you mean to unbolt the universal so it can move more freely?
Old 04-29-2024, 11:03 AM   #6
JayJay
Just did this a couple of weeks ago. Keep spreading the spring, it will line up. Also, be sure you’re not hung up on the shock ball on the axle housing. Then spread the spring some more. It gets really tough and tight towards the end, then Presto! You’re in.
Be sure you are about equal on the two sides of the spreader, you want to keep it centered on the spring.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is offline   Reply With Quote
Old 04-29-2024, 11:15 AM   #7
1912Krit
Thanks JayJay. I will do as you recommend. I was just getting a little nervous about the tension. Doing it equal in both sides. I took out the shackle that was half way in to free the rear end up to move.
Maybe the solution is to install both sides at the same time. The books say do the passengers side first but that didn't work out so well.
Thanks again,
Don
Old 04-29-2024, 11:20 AM   #8
Benson
deleted ... since process did not work in this case.
I used a modified version of this process in the 60's that we used 15 or 20 times which did not involve a spring spreader.
Benson is offline   Reply With Quote
Old 04-29-2024, 04:28 PM   #9
1912Krit
Thanks Mr Benson, will try your method.
Don
Old 05-02-2024, 07:46 PM   #10
1912Krit
Success. Just took me a bit of perseverance in tight quarters. I couldn't use Mr Benson's method. I tried but the bottom lip on the spreader bar is lower than the spring end, so it dug into the wood and wouldn't slide.
I can see how the spring end sliding on the wood can work well.
Thank you gentlemen for your advice and support!!!
Old 05-02-2024, 07:49 PM   #11
1912Krit
Photo of spreader
Old 05-02-2024, 07:55 PM   #12
JayJay
Glad everything worked out well, Don. It is a satisfying feeling when the shackle slides into place and you can let off the spring spreader.
JayJay
Old 05-05-2024, 03:14 PM   #13
1912Krit
Absolutely! Thank again for the coaching.
Old 05-05-2024, 05:14 PM   #14
Flathead
Flathead's Avatar
Grease the hell out of them!!
Flathead is offline   Reply With Quote
