Old 04-23-2024, 11:38 PM   #1
Brennan805
Default Packing Differential Bearings?
Hey Guys-
I just finished a complete rebuild on my Dana 41 Diff complete with new 3:54 gears. I've done a few Banjo's and Dana's in the past and feel pretty comfortable with the job. I've always packed the bearings with an all purpose, automotive grease and never thought anything of it. I was reading an article recently specifically about differential lubrication and it stated never to pack the bearings with grease and to only use 90wt gear oil for the assembly. Their reasoning was that the grease will eventually separate in clumps clogging critical lubrication channels and ports. Also, High temp wheel grease may not completely dissipate over time. After reading the article, I assembled the Dana 41 with only 90 wt. gear oil.
I'm curious to know your thoughts?
Brennan805 is offline   Reply With Quote
