#1 |
I'm in the process of setting up a Lincoln [hypoid] rear end. I'm quite familiar with how to set up a banjo rear, having done numerous Fords over the years, but I don't know the specs for backlash between ring and pinion for a Lincoln. Does anyone have the specs? [measured at the spline]. Thank you!
#2 |
I have it written down with other notes and bearing and pinion seal number from when I rebuilt my 39 Zephyr rear axle. . I’m away from the shop now but maybe later this afternoon.
#3 |
Think those parts came as an assembled pinion/ housing and ring gear so no specs were published. At least none ive been able to find. I would say tooth contact pattern is more important than lash with those
#4 |
I finally found the information I was looking for.
#5 |
#6 |
#7 |
I've finally located the data I was searching for.
