Old 04-10-2024, 03:44 PM   #1
V8guy
V8guy's Avatar
Default 1935 oil pressure gauge connections
Connecting the oil pressure gauge 6 volt lead from switch to the top terminal and sending unit lead to the bottom or-???
Thanks Mike
V8guy is offline   Reply With Quote
Old 04-12-2024, 07:18 AM   #2
Terry,OH
Terry,OH's Avatar
Default Re: 1935 oil pressure gauge connections
The sender uses the engine block polarity (+ ground) so there is no need for a wire. The wire on the top of the sender goes to the pressure gauge. The gauge has two electrical terminals one for the wire to the top of the sender and the second for battery (-). The 35 Ford oil pressure gauge gets it's battery (-) from the ignition resistor connections. One of the two connections for the resistor is battery (-) from the ignition switch.
