Old 04-10-2024, 03:18 PM   #1
Phil Gillespie
Phil Gillespie's Avatar
Default 1955 Ford Customline Ride Height.
1955 Ford Customline has been fitted with new rear springs.
Previous owner had this work done. Looks ok maybe still sitting a little high.
Can any body give the ride height, as taken from centre of rear tail light to ground?
Many thanks in advance.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 04-11-2024, 06:44 AM   #2
KULTULZ
KULTULZ's Avatar
Post Re: 1955 Ford Customline Ride Height.
The factory trim height should be found in the 1955 FORD WORKSHOP MANUAL if you have a copy.
Do you want the factory stance or do you want to change it?
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 04-11-2024, 05:41 PM   #3
Phil Gillespie
Default Re: 1955 Ford Customline Ride Height.
Just want the factory stance to cross check it. Not looking to change it.
Dont have the factory manual.
Thanks Phil Nz
Old 04-11-2024, 11:49 PM   #4
KULTULZ
KULTULZ's Avatar
Thanks Phil Nz
Let me go to my 'COBWEB CORNER' and dig my copy out and I will try to find it.
If you take it off another car, that car may not be sitting right.
https://www.themotorbookstore.com/se...=1955+ford+car
Old 04-12-2024, 04:26 AM   #5
Phil Gillespie
This will be great as I'm so lloking forward to owning this vehicle again.
Hopefully take over next week.
many thanks
Phil NZ
Old 04-12-2024, 01:36 PM   #6
miker98038
miker98038's Avatar
Those manuals are available as reprints from a number of sources. But given your location, an online version might be better. They're only around $17.00 US.. I don’t know these guys, but you can view the sample and check around.
miker98038 is offline   Reply With Quote
Old 04-13-2024, 03:32 AM   #7
KULTULZ
KULTULZ's Avatar
Cool Re: 1955 Ford Customline Ride Height.
I am still in SEARCH MODE. I have a BUNCH F*CK down there ...
Anywho, this (IMO) is the minimum one needs to work on his/her/it's car ...
- https://www.themotorbookstore.com/19...anuals-cd.html
Read the complete page. This will give you about all you will need.
Old 04-13-2024, 08:05 AM   #8
Ford blue blood
Ford blue blood's Avatar
Yup! First thing I do is find every manual that the factory put together for that car. Save me (and many parts) many times in the "apart and together" phase of building! Can't strongly enough recommend those purchases.
Bill, certified Ford nut.
2024 F-150
2018 Lincoln MKZ
2016 Focus
1961 Comet S-22
1956 Ford Crown Victoria
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 04-15-2024, 02:26 AM   #9
Phil Gillespie
Have only come up with overall height being mentioned. In vicinity of 61".
Phil NZ
Old 04-16-2024, 11:52 AM   #10
miker98038
miker98038's Avatar
I know that’s in the manual someplace, but I dug mine out and damn if I can find it. If some knows, point me in the right direction.
I posted in the social group over on the HAMB, but this is all I got back so far. Courtesy of jimmy six, who owns a 56
“Real ride height is measured at the frame rails. The frame should be parallel to the ground thru the flat area at the firewall to where the front of the rear spring perch mount.
Rear springs all have sag after a year of being new and so o the fronts but not as quick. Hope you can get good numbers .”
Old 04-16-2024, 05:53 PM   #11
KULTULZ
KULTULZ's Avatar
Phil NZ
VICINITY is only close in horse shoes, hand grenades and thermonuclear warfare.
Proper trim height is dictated by body style, drive-line, size of tires, etc. Spring rates (and maintained suspension) is what gives correct trim, not vehicle roof height off a level floor.
Let me venture back into the BLACK PIT and see if I can find my copy.
A TECH not only needs it for crash repair but also aligning the suspension.
If the attached ILL shows large enough, it is a GENERIC diagram (not FORD ) of how TRIM HEIGHT is measured -
2nd ILL attached I believe is from a FORD WSM -
Old 04-20-2024, 04:28 PM   #12
Phil Gillespie
So I finally took delivery of the 55 Customline.
Rechecked the height front and rear.
Front Headlight centre to floor: 840mm.
Rear: Tail light centre to floor: 860mm.
Sitting on Cooper tyres 205 70R 15 all round.
There is at present 6 leaves either side. Reported that an extra leaf was added. This is evident by inspection. So by eye up slightly in the back car unlaidened.
I can live with this as visually looks fine.
Phil NZ
Old 04-21-2024, 11:41 AM   #13
scicala
scicala's Avatar
Passenger cars had 5 leaf rear springs. With the police interceptor option they had 6 leafs. Wagons and Courier had 7 leafs.
Sal
