Old 03-30-2024, 02:49 PM   #1
Tim Ayers
Default How or what hardware to install interior door panel on ‘28 roadster?
I thought I had want I needed, but I don’t. What hardware is used to install the interior trim panel to a ‘28 roadster door? I looked on line but I must be calling it the wrong name. Thanks
Old 03-30-2024, 02:56 PM   #2
brito36
Default Re: How or what hardware to install interior door panel on ‘28 roadster?
You need the fasteners that insert into the door panel along with upholstery nails. The heads are larger(about 1/4 in.) than regular upholstery nails. Some of the earlier heads had a 'spatter design' nail head. You appear the have the correct fasteners in the door.
brito36 is offline   Reply With Quote
Old 03-30-2024, 06:40 PM   #3
Tim Ayers
Thank you. Do you know what they are called? I can’t seem to locate them on vendor’s websites
Old 03-31-2024, 12:05 PM   #4
Upholstery Mike
Hi Tim,
They are called screw nails. They are available in black or brown. They are listed under hardware and yard good on the Classtique Upholstery website. There are many fasteners that only sold by Classtique Upholstery.
Upholstery Mike is offline   Reply With Quote
Old 03-31-2024, 12:20 PM   #5
Tim Ayers
Originally Posted by Upholstery Mike View Post
Hi Tim,
Thank you!
Old 03-31-2024, 12:51 PM   #6
Jim Mason
Jim Mason's Avatar
Example from early Tudor
www.jmodela.coffeecup.com
Fwiw, jm.
Jim Mason is offline   Reply With Quote
Old 04-01-2024, 07:49 AM   #7
Tim Ayers
Thank you
