#1 |
1948 how to remove snap ring on rear hub in front of grease seal;,
Thanks |
#2 | |
Pry the ring away a little with the screwdriver and put yet another a little "further down the line. Soon enough you'll be able to grasp the "loose end" of the ring with a locking pliers and pull it out the rest of the way. Before reinstalling the ring, cut the "other end" in the opposite direction it is currently in so you may use a snap ring plier next time.
