#1 |
I got this for free, had it recored and finished, but it is wrong for my 39. Can anyone tell me what it goes to so I can list it and maybe get some of my refurb money back?
Thanks! Last edited by coxswain98; 03-25-2024 at 12:07 PM. Reason: Add pictures |
#2 | |
Looks like a '37 to me... |
#3 |
It does look like a '37. I will compare it to a '37 radiator I have. It most likley could be a service replacement type of the period.
#4 |
It is too narrow where it mounts to the frame and the hose connections are not under the tank overhang. Are ‘38 and ‘39 different from ‘37?
#5 |
1939 Is completely different. More square and split core. Deluxe anyway!!! Not sure about Standard?? AND you would also have to specify 38 Standard or 38 Deluxe
#6 |
Look how the intlet necks on the top tank angle towards the center of the heads. If they were under the tank they would be more straight down for water pumps on the heads. This radiator suggests water pumps on the block and water inlets on the center of the heads. That puts it at 1937-1938 in my opinion. The small brackets on the sides of the straps at the top are where the hood sides attach. It also has the side air deflectors like a '37 radiator. There would be a center air deflector mounted to the grille on a '37. That part keeps you from seeing through the grille from side to side. Often missing and mostly for looks. Can you show us a photo of the number that is molded into the top tank? Last edited by Seth Swoboda; 03-25-2024 at 02:59 PM. |
#7 |
What about 60HP?? They are narrower.
37 Passenger car radiators 85hp core size 23 X 17 78-8005-A 60hp core size 21-3/4 X 15-3/4 74-8005A Commercial Radiator 37 85 hp 22-1/2 X 19-3/4 77-8005-A 60Hp 22-1/2 X 19-3/4 73-8005A 1938 were the same measurements as 37 for both 85hp 81A-8005-A 60Hp 82A-8005-A 85Hp Comm 81C-8005-A 60Hp Comm 82C-8005-A Last edited by rockfla; 03-25-2024 at 03:12 PM. |
#8 |
Super Moderator
Not 39 standard. At least it doesn't appear to be.
Does the top tank have any embossments upon it?
"I can explain it for you. However, I can't understand it for you". Last edited by Kube; 03-25-2024 at 04:36 PM. |
#9 |
#10 |
Shure looks like a 60 hp to me. The tank hangs over the front on them.
#11 |
Super Moderator
The attached picture is the only one I have that depicts a '39 standard 60HP radiator.
The other photo is a '39 standard 85HP.
#12 |
The embossment says D4
#13 |
Ah, just measured the core at based on all your wonderful help, it seems to be a ‘37 radiator for a 60 hp. Well, at least I can list it properly.
Thanks for the help! |
#14 |
Visible on the inner side of the top tank is the identifier D4. This is a 1938-1939 60 hp 82A-08005-A2 McCord design with core 74-8005-D4: From the 1938-39 Ford Book published by the EFV8CA page 4-3.
Alan |
#15 |
#16 | |
I don't think it is a 37 V8 60 truck radiator. I restored a 37 Ford 85 HP pickup in the early 1960's. I was sold a NOS radiator that had wider side mounting fins and the fill neck was spaced forward on the tank. I was told the radiator was a "desert, high capacity option". I did not note that the upper and lower tubes were smaller than an 85 hp radiator when the I bought the radiator. The radiator fit the chassis perfectly, however the shell would not fit onto the radiator. I still have the radiator hanging in my garage. Pix attached.
Bill.... 36 5 win cpe Last edited by blucar; 03-26-2024 at 09:59 AM. |
#17 | |
