Old 03-10-2024, 07:16 PM   #1
48fordconv
Default 48 Ford gas fitting going into gas tank
I'm replacing fitting on side of gas tank. How far should the line go through fitting into tank, thanks
48fordconv is offline   Reply With Quote
Old 03-10-2024, 07:32 PM   #2
19Fordy
19Fordy's Avatar
Default Re: 48 Ford gas fitting going into gas tank
This thread will help.
https://www.fordbarn.com/forum/showt...s+tank+fitting
Old 03-10-2024, 10:01 PM   #3
FortyNiner
FortyNiner's Avatar
The configuration is different for 46-48 compared to the 40.
The fuel line doesn't extend into the tank through the fitting, if I understand the question.
If you are replacing the pickup tube inside the tank, then the other thread is your answer.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 03-12-2024, 09:35 AM   #4
Topher5150
I was looking at my tank the other day and it looks like there is a line that runs from the outlet on the side to about half in.
Topher5150 is offline   Reply With Quote
Old 03-12-2024, 01:06 PM   #5
19Fordy
19Fordy's Avatar
It would seem logical that the "out flow" gas tank line fitting would have to have the gas line extend inside the tank long enough so that it bends downward but does not touch the bottom of the tank. Otherwise, you won't be able to use up the gas in your tank.
Old 03-25-2024, 10:39 AM   #6
matterick
Following
matterick is offline   Reply With Quote
Old 03-25-2024, 10:45 AM   #7
Kube
Kube's Avatar
If I understand correctly, you are replacing the fitting at the end of the fuel line. Correct? If so, the line needs to extend no more than 1/2" beyond the end of the fitting.
