#1 |
So, from a recent previous post you may know that I pulled my 21-stud engine and transmission from my 37 Coupe. I did this to reseal both and resurface the flywheel and replace the clutch and pressure plate. Ring gear was worn so I order a new one and had that replaced when the flywheel was resurfaced. The issue is that the flywheel, clutch and pressure plate are an 11" setup, which I now see is for a truck. (My first flathead) I know that engine was rebuilt at some point, as the crank is stamped .020 under. The transmission S/N does not match the frame S/N just FYI. After I bought the car, I did the normal maintenance items and had Skip rebuild the coil and Michael at Third Gen rework the distributor, and the engine runs great and has good acceleration even having a couple slightly lower compression reading cylinders. Also has a Columbia rear end and this thing moves along nicely at highway speeds. Should I just go back with the 11"? Or attempt to locate a flywheel for the 9" setup. After a quick search, that may be a challenge. Nate
#2 |
Did the 11" clutch and pressure plate work okay? It seems like overkill but if it worked why change it?
#3 |
Purchased the car in 2019 and put maybe 1500 mile going to local car shows and just goofing off. Runs great. Clutch wasn't slipping but was at its adjustment limit.
#4 |
#5 | |
![]() Quote:
#6 |
#7 |
I'd say put a new disk and pressure plate on and go. Otherwise you'll need to find a '37 flywheel and a 9' pressure plate and disk.
#8 |
Have the flywheel redrilled for a 9" clutch plate. Use the best shouldered bolts as possible.
#9 |
I sent you a private message.
Tom |
#10 |
There is nothing wrong with an 11"clutch. It's a bit heavy and isn't necessary in a car. either is a 10". However, what's done is done. I use anly the9.5 but that eon't work with the early trans/
Gramps PS indina clutch can beef up a 9" |
#11 |
If the 11 inch works well, keep it.
#12 |
Well, it was working fine, and since I have already replaced the ring gear and had it resurfaced, that is what I will do. Appreciate everyone's input as always. Nate Anello
#13 |
If this car has been running a 11" clutch look in the front of the transmission bell housing for marks that the pressure plate may be hitting the casting.
#14 |
Terry, I appreciate your question and checked the transmission bell housing and find no witness marks where it could have been rubbing. I had no unusual noise in the driveline in the 4 years I have been driving the car prior to disassemble. Serial number of transmission, although it doesn't match the frame number, does show transmission is a 1937 era.
But I am curious now, is this a common / known issue with the 11" pressure plate rubbing on trans housing or back of engine upper trans housing? Nate |
#15 | |
![]() Quote:
#16 |
Common?? It sometimes happens with an 11" sounds like your good.
#17 |
It should feel much better with everything fresh. Run it and enjoy. I need the post count, thanks.
#18 |
Good info to note for mine..
