Old 02-04-2024, 11:02 PM   #1
KeeKeeBoy46
KeeKeeBoy46's Avatar
Default Shocks
Greetings guys. Like to hear some feedback regarding replacement or repair of 1940 Ford shocks. Not cheap.....yikes !! Kenny C
KeeKeeBoy46 is offline   Reply With Quote
Old 02-04-2024, 11:24 PM   #2
tubman
tubman's Avatar
Default Re: Shocks
If you want to do it yourself, check this thread out : https://www.fordbarn.com/forum/showt...=andy+falandes.
Otherwise Andy Falandes has a good reputation : [email protected].
Old 02-05-2024, 08:20 AM   #3
corvette8n
corvette8n's Avatar
Default Re: Shocks
I had Andy rebuild the shocks on my ‘41, I sent him the fronts one year and the backs another. I was going to convert to tube shocks, but figuring the cost of brackets and tube shocks it was easier and quicker to have the originals rebuilt.
Old 02-05-2024, 08:35 AM   #4
jimTN
Default Re: Shocks
Pricing on rebuilt shocks is high. I would like to see a breakdown on labor hours and parts that go into the price.
jimTN is offline   Reply With Quote
Old 02-05-2024, 09:46 AM   #5
Kube
Kube's Avatar
Default Re: Shocks
Along with labor hours and parts, be certain to add the knowledge to do the rebuilding, the cost of the tools and fixtures, etc.
Me? Around $200 each to properly rebuild a shock is well worth the cost.
Old 02-05-2024, 09:51 AM   #6
DavidG
DavidG's Avatar
Default Re: Shocks
jimTN,
You always have the option to do it yourself, that way you will know firsthand what labor hours and parts are involved.
Old 02-05-2024, 10:12 AM   #7
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Shocks
Probably can make more per hour working flipping burgers let alone pay for the tools and machinery.
It’s not like you can buy the cartridge to drop in anymore have to make parts
Old 02-05-2024, 11:43 AM   #8
TJ
TJ's Avatar
Default Re: Shocks
Take an old shock and see how long it takes you to get it apart without the proper tools.
Old 02-05-2024, 12:06 PM   #9
Kens 36
Kens 36's Avatar
Default Re: Shocks
Good one Tom!
https://www.nirgv8.org
Kens 36 is offline   Reply With Quote
Old 02-05-2024, 01:59 PM   #10
Seth Swoboda
Seth Swoboda's Avatar
Default Re: Shocks
I've tried and had no success.
I wish there were more folks who would eventually pass along these specialty rebuild skills. For example rebuilding shocks and coils. It seems like there are only a few or sometimes one person nationwide that do these rebuilds. What if something were to happen to them? It would seem that particular service would be lost forever or until someone successfully figured out the procedure.
Seth Swoboda is offline   Reply With Quote
Old 02-05-2024, 02:08 PM   #11
1942deluxe
1942deluxe's Avatar
Default Re: Shocks
Are your rear shocks marked F 745 by any chance? I bought a NOS one that I thought
would fit my 42 but was mis boxed. If it's the same and you need it it's available.
Old 02-06-2024, 11:00 AM   #12
Fred A
Fred A's Avatar
Default Re: Shocks
Let's recall that that Ford added a front sway bar in 1940, which made it harder to just bolt on tube shocks to the front end. With or against this, I have been able to find plenty of cores, correct for the '40 front, and not so many in good working condition for the rear. Not a scientific sampling, but being a thrifty guy, I notice. Of late, I marched the whole Turlock event and found zero shocks. Had I wanted Blue Blocker Sunglasses or other... Depends on your needs or wants. Good Luck: Fred A
Fred A is offline   Reply With Quote
Old 02-06-2024, 12:31 PM   #13
1942deluxe
1942deluxe's Avatar
Default Re: Shocks
There were two NOS front 40 shocks (or so marked) at the Hamburg NY swap meet Sunday. Saw Charlie NY there. He said to tell everybody hello.
Old 05-03-2025, 06:52 PM   #14
s.e.charles
s.e.charles's Avatar
Default Re: Shocks
[QUOTE=Fred A;2289159]Let's recall that that Ford added a front sway bar in 1940, which made it harder to just bolt on tube shocks to the front end. ... [QUOTE]
would anyone happen to have a link or picture of this from underneath?
i've seen isometric drawings and top 45 degree photos, but i am not clear how the sway bar ends connect to the axle. dogbones, too?
thanks
sid
s.e.charles is offline   Reply With Quote
Old 05-04-2025, 06:37 AM   #15
Terry,OH
Terry,OH's Avatar
Default Re: Shocks
There are two very different sway bars for 1940 each had their own different attachments to the axle. Even the perch pins are different. The early style was discontinued, removed from some vehicles due to noise, taken out of stock, returned to the factory by dealers for credit and replaced by the later style, which is very common.
Old 05-04-2025, 06:48 AM   #16
s.e.charles
Default Re: Shocks
it's for a scale model, so a photo of the latter style would be most appropriate.
thanks for the information. i understand, and which has piqued my interest in this period of automobiles, is the amount of changes which were taking place. hydraulic brakes for example. and transverse suspension changing over to semi-elliptic springs and "airplane shock absorbers."
