#1 |
Does anyone have a photo of an original decal which is located on the side of the 1937 Oil Bath Air Cleaner (Part No. 79-18205)? I have a copy of a United Air Cleaner advertisement (see attached) but the image not sharp enough to read the label. There is a reproduction label available and I'm just trying to verify the reproduction is true to the original version of the label and also determine when the Ford Script in the bottom right was added to the design.
1935 157" 1 1/2 ton stake truck undergoing full original restoration 1936 131 1/2" panel truck rescue preservation Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America |
#2 |
#3 |
Thanks for the image, but that's the same reproduction label I shared in my post. I'm looking for a picture of an original decal still on an original air cleaner. The decal doesn't have to be perfect, just mostly readable, especially the script Ford, or lack of the script Ford.
#4 |
#5 |
Why can't you print the image? Looks eminently readable to me. Then make your own decal by laminating the print. I've even used clear packing tape to make a durable laminate.
#6 |
#7 |
![]() So what do you 'guess' the decal would look like without the Ford script? |
#8 |
I don't have to guess as I already have camera ready artwork for the image you attached.
You seem to be missing my fundamental question. I want to know when, or even if, Ford changed the decal and added the Ford script. I want supporting information such as a Ford Engineering drawing or an image of a decal on an original oil bath air cleaner. I'm not sure why you don't understand.
#9 |
I'm not sure either.
Perhaps someone else has supporting information such as a Ford Engineering drawing or an image of a decal on an original oil bath air cleaner that will indicate with 100% certainty when, or even if, Ford changed the decal and added the Ford script. How's that sound? |
