Old 01-28-2024, 01:31 PM   #1
khnaess
Default Leaking waterpump 60hp
Hello
I have this 1937 v860 and I noticed that there is som water coming out of the little hole (se arrow on picture) from my left water pump. The car has been sitting for a couple of months. Is this some quick fix or do I have to pull the pump? I can live with some small dripping once in a while but the way it is now is too much because the fan belt throw water all over the engine bay.
thanks
Knut Haakon
khnaess is offline   Reply With Quote
Old 01-28-2024, 01:40 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Leaking waterpump 60hp
Originally Posted by khnaess View Post
Hello
thanks
Knut Haakon
Old 01-29-2024, 03:31 AM   #3
khnaess
When I grab the pulley at the end of the waterpump and try to move it sideways (up and down), I can feel its kind of loose. The other waterpump does not have these sideways movement. I guess this is a sign of badly worn pump?
Also, can anyone from the picture see what kind of wrench I need to loosen this pump? I know there is two types out there...
Old 01-29-2024, 08:01 AM   #4
jimvette59
jimvette59's Avatar
YUP it needs to be repaired or replaced. That's why that hole is there.
jimvette59 is offline   Reply With Quote
Old 01-29-2024, 09:29 AM   #5
Steve in Denver
Steve in Denver's Avatar
See who has a couple of rebuildable ones to sell you and send them to Skip Haney 941-639-0920, [email protected] in Florida to be rebuilt. When you get them back, you can do the whole job in a day.
Steve in Denver
Steve in Denver is offline   Reply With Quote
Old 01-29-2024, 10:16 AM   #6
khnaess
Thanks!
But I guess they are not easy to remove without the special spanner tool?
Old 01-29-2024, 10:36 AM   #7
KiWinUS
KiWinUS's Avatar
Are you sure Skip does 60 pumps?
Old 01-29-2024, 12:09 PM   #8
Kube
Super Moderator
Kube's Avatar
Thanks!
Yes, a spanner wrench is required. And yes, the pump is at the threshold of failure.
And finally, as Kiwi has suggested, check with George as to whether or not he rebuilds these pumps. I do not believe he does.
Old 01-29-2024, 02:33 PM   #9
Tim Ayers
I believe the V8 60 pump rebuild kits are kind of plug and play. You unscrewed the old internals using the V8 60 specific spanner and put the new one in. These kits are available. I'd check Ebay and the like.
https://www.ebay.com/itm/14298847061...Cclp%3A4429486
I believe the seller above is the old Kanter Auto Parts
https://www.ebay.com/itm/27615195100...Bk9SR66Hy-uqYw
This style is what you typically see. The complete unit.
Old 01-29-2024, 03:52 PM   #10
Kube
Super Moderator
Kube's Avatar
[QUOTE=Tim Ayers;2287355]I believe the V8 60 pump rebuild kits are kind of plug and play. You unscrewed the old internals using the V8 60 specific spanner and put the new one in. These kits are available. I'd check Ebay and the like.
Keep in mind there are two different pumps. One has a flat "face" while the other is tapered. They are not interchangeable.
Old 01-29-2024, 03:58 PM   #11
Tim Ayers
[QUOTE=Kube;2287376]
Ah. I did not know that. Thanks for the tidbit.
Old 01-29-2024, 05:48 PM   #12
JayChicago
JayChicago's Avatar
[QUOTE=Tim Ayers;2287379]
The devil is in the tidbits.
JayChicago is offline   Reply With Quote
Old 01-29-2024, 09:13 PM   #13
L-head
The early pumps (37) were tapered and sealed with a couple of seals located on the taper. Later pumps (38-40), which yours appears to be, has a flat gasket or ring behind the lock ring and the timing cover. Red's Vintage Parts.Com has a list of 60hp parts and lists repro pump spanner wrenches for both type pumps. Most of the kits have both types of seals, the impeller, brg, spring, rubber nose cover will fit either type pump. I did not see any kits on this web site. They are rebuildable.
L-head is offline   Reply With Quote
Old 01-30-2024, 08:44 AM   #14
Kube
Super Moderator
Kube's Avatar
All of what you say is factual. However, I'd add a cautionary note... many of the timing gear covers have been changed in the past. So, until the original poster knows for certain what he has there, well, he'd be wise to hold off on purchasing any parts.
Old 01-30-2024, 08:58 AM   #15
KiWinUS
KiWinUS's Avatar
These pumps are simple and basic BUT without the correct tools can be a challenge to rebuild without the correct tools. Very easy to damage pumps and break pulleys. Must face mating surface of housing where impeller mates. I have rebuilt many but I now have correct tools including some I made.
Old 01-30-2024, 09:04 AM   #16
Tim Ayers
Thanks, Tony. Cheers.
Old 01-31-2024, 01:30 AM   #17
khnaess
Thanks all! Water pump rebuild kit and spanner wrench are now ordered so I guess I give it a shot. Wish me luck��
Old 01-31-2024, 10:47 AM   #18
Kube
Super Moderator
Kube's Avatar
Did you have the tapered pumps or "flat"?
Old 01-31-2024, 02:59 PM   #19
KiWinUS
KiWinUS's Avatar
Make a tool to remove pulleys in pulley grove NOT BACKSIDE OF PULLEYS
Old 02-19-2024, 02:06 AM   #20
khnaess
I finally got the pump off�� But I have a question about the gasket , see pictures. There seems to be a double gasket (one leather and one cobber) where the pump seal to the timing cover ? Is this original ? I cannot se the copper seal on any drawings and the repair kit only contain one leather seal.
