01-14-2024, 12:40 AM | #1 |
Brake/clutch return springs hook where?
‘39 Standard coupe.
I see in the Green Bible where they hook to the pedals, where does the other end hook onto? Anyone have pictures? Thanks! |
01-14-2024, 01:06 AM | #2 | |
Re: Brake/clutch return springs hook where?
Look for little tiny holes in frame rails and transmission mounts, for instance. I believe the 1st pic BELOW is a '37 Ford. I'm pretty sure the 2nd, 3rd and 4th pictures BELOW are '39 Ford. Coop |
01-14-2024, 10:53 AM | #3 |
Same question but on a 40. Is it the same? Thanks!
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/ |
01-15-2024, 02:30 PM | #4 |
Not the same as 1940. Both the brake and clutch pedal return springs are different. The 40 springs are pictured below
01-15-2024, 03:08 PM | #5 | |
01-16-2024, 11:34 AM | #6 |
01-16-2024, 09:05 PM | #7 | |
The picture BELOW is for sure of a '39 Ford brake/clutch pedal assembly. It can be clearly seen that the BRAKE spring is the smaller one toward the right in picture and goes to a small hole in lower frame rail. Coop |
01-17-2024, 01:09 AM | #8 |
Now that’s a good picture, thanks! It seems that I am missing some holes in my frame. I’ll drill one. Anyone know the dimensions to locate this hole?
01-17-2024, 07:05 AM | #9 |
The 39 brake and clutch pedal spring are the same. It is pictured below 5.40" OAL. I would not think you have to drill another hole. Are the pedal stop bumpers in place??
