#1 |
I looked at the tag on the passenger side of the firewall and as far as I can tell it is: BOL U1 20561 Can anyone decode this for me? The L might be a 1. Thank you
#2 |
B = V-8, 0 = 1950, LU = Louisville assembly plant. 120561 = sequence number of 1950 engine production at that plant.
Ken
https://www.nirgv8.org |
#3 |
#4 |
I was looking for the vin number for the car but the serial number tag was all I could find. Nothing on the glove box door or anywhere else on the firewall. On the title that came with the car the vin# is: 98RC408449 - year 50 - make Ford - body PK Do you think this title goes with this car? Thanks
#5 |
#6 |
#7 |
Boom,
The serial number IS the VIN on these cars. The serial number shown in your first post is for a 1950. The serial number on the title is for a 1949 V-8 Ford build in Richmond. Ken
#8 |
98RC prefix was common for the 1949 & 50 Ford F1 pickup. The 8R indicates V8 and the C indicaes the F1 commercial vehicle (pickup). The specific number 9 was carried over after 1949 due to Ford development of a new VIN system. The pickup glove box tag was too easy to remove and transfer. 1948, 49, & 50 pickups had body & trim information stamped into the cowl/firewall sheet metal where it was painted over and it hard to read.
Mercury cars have a firewall or cowl tag for Body ID and exterior/interior trim codes. The 1949 Ford cars were just stamped into the upper cowl/firewall panel and are harder to find sometimes. Body tags showed up in 1950 or so. The Ford, Mercury, and Lincoln frames were always stamped with the basic VIN but locations vary between different model types and years. By 1952, all the cars had body tags. Last edited by rotorwrench; 01-06-2024 at 01:30 PM. |
#9 |
rotorwrench, thanks for clarifying that this is a pickup ID number. I've corrected my previous post.
#10 | |
![]() Quote:
#11 |
Tubman are we talking car or pickup? If car, the number was on the angled brace for 49 to 51. In the V-8 Club's 49-51 Ford book the info is on page 1-16. It was only the 50 and 51s that they included the assembly plant in the code.
#12 |
on my 1950 Convertible thereīs a riveted tag on a firewall with a VIN number. However it doesnīt have a stamped codes on the firewall that would give me the original color/plant etc info. Is there another location where this stamping could be ? I donīt understand why itīs not on the firewall
#13 |
Those codes were only on the firewall and may appear above or below the protruding seam, depending on the assembly plant. They may disappear under coats of paint, but they are there.
Ken
#14 |
