Old 01-05-2024, 01:48 PM   #1
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Carburetor Fuel Level Gauge - Suggestions on making one please?
Our fuel level gauge has gone missing, and it appears they are out of stock, -so I guess I need to make one. Therefore I need a little inspiration.
If I were to use a regular carburetor drain, it appears I have around 3/16" of an area inside of the plug that could be drilled, ...then a small length of 3/16" O/D steel Brake line installed and JB Weld added to hold it in. It appears McMaster has 3/16" clear tubing. Before I go thru the steps of this, does anyone know of an easier way to make one of these??
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
