01-02-2024, 12:42 PM | #1 |
Columbia Rear install info
I’m installing a Columbia kit from John Connelly on my ‘33 Tudor. What diameter and length of copper tubing do I need? That’s the only thing not in the kit. Hopefully someone has done this before. Thanks.
Tim Carlig |
01-02-2024, 03:18 PM | #2 |
Re: Columbia Rear install info
I can tell you how I did my "32". I ran parallel 3/8" copper on the inside of the passenger frame rail. I was able to pass it between the K-member and the frame where I extended to the control valve with rubber hoses. At the rear I stopped at a point and kicked it out slightly, where the rubber hose could be attached without kinking. To hold the copper on the frame I used John Connelley's S.S. B-60 clips. I purchased a soft copper roll and a 3/8" tubing straightener. John has an illustration, Page 4 of 10 in his catalog for 33-34 to give you a good idea how it's ran.
01-02-2024, 03:19 PM | #3 | |
01-02-2024, 04:18 PM | #4 | |
Tim Carlig |
01-02-2024, 05:34 PM | #5 |
How Many feet??
My car is a custom job for a "32". My two piece were 4 foot each. Maybe someone who did an installation on a 33-34 can chime in. 3/8" soft copper usually comes in a 25 ft roll at the hardware store, so you will have plenty. You can get a straighter on Ebay, they're not expensive, this one is size specific. |
01-02-2024, 05:55 PM | #6 | |
Tim Carlig |
01-02-2024, 06:04 PM | #7 |
01-02-2024, 06:28 PM | #8 |
Originally it was 3/8” copper coated steel line. If you’re not concerned with what’s correct , brake line works well.
01-02-2024, 07:16 PM | #9 |
He's not at all concerned with correctness.
01-02-2024, 07:17 PM | #10 |
What is a straghtENER? Did you mean a straightener?
01-02-2024, 07:28 PM | #11 |
Ken, why, because the car already had DeLuxe additions/upgrades and I continued in that direction? I like my cars stock and original as possible. I didn’t see any sense to remove the DeLuxe additions already added.
Tim Carlig |
01-02-2024, 07:33 PM | #12 | |
In fact, as it wasn't offered by Ford in 1933, it isn't aligning with keeping your car stock.
01-02-2024, 07:43 PM | #13 |
01-02-2024, 07:47 PM | #14 |
Ford, 1941.
01-02-2024, 08:13 PM | #15 |
I thought Ken was referring to my woodgraining my dash and garnish mouldings. Blasphemy!! Ford/Lincoln Zephyr authorized Columbia’s in 1937.
Tim Carlig |
01-02-2024, 08:15 PM | #16 | |
Ford? Not until 1941.
01-02-2024, 08:31 PM | #17 |
From the Ford club restoration manual for 33-34, page 2-3.
Tim Carlig |
01-02-2024, 08:40 PM | #18 |
01-02-2024, 09:13 PM | #19 |
I had no clue as to how you think you know my feelings about what is correct or not Ken.
Tim Carlig |
01-02-2024, 09:20 PM | #20 |
