01-01-2024, 07:07 PM | #1 |
dana 41 outer axle bearing upgrade?
Howdy boys, working on grandads '48 F1 with a Dana 41 rear differential. Question on the outer bearing for the axle shafts. I have Timken number 514003, which is a sealed bearing. Is it a replacement for what all of the parts schematics I have looked at, show as a tapered bearing? The Dana 41 was used in the early jeeps also. I've looked, but can't find anything definitive. And, for some unknown reason, I seem to have discarded the old bearings. Damn it, I usually keep everything until it's finished. Must have had my head in the wrong area that day. Thanks guys!
01-01-2024, 07:25 PM | #2 |
Re: dana 41 outer axle bearing upgrade?
The Dana 41in the early Jeeps had a tapered hub, guessing the bearing is different. M series Studebakers had a 41, but I believe those had tapered hubs as well.
I dig coal, which provides motivation for EVs. |
01-01-2024, 07:34 PM | #3 | |
Parts > https://www.kaiserwillys.com/nsearch...rch_return=all
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 01-01-2024 at 11:01 PM. |
01-01-2024, 11:11 PM | #4 |
Pete, I have this schematic, it shows the tapered bearing. My axles have the flange on the axle, no taper. I have sealed bearings. They must be correct for my application. Wish I could find a schematic for the Dana 41 I have. They must be out there. Thanks guys!
01-02-2024, 01:23 AM | #5 | |
01-02-2024, 05:45 AM | #6 |
01-02-2024, 09:58 AM | #7 |
Thanks Pete, I looked, they are for Jeeps, not '48 Ford pickup.
01-02-2024, 09:59 AM | #8 |
Henry, I'll give chuck a try. Thanks!
01-02-2024, 10:09 AM | #9 |
Henry!! That's exactly what I was looking for! You are..... The Man! Thanks!
01-02-2024, 10:18 AM | #10 |
9” ford bearings I believe. The jeep uses Dana 41 but different axles with taper.
01-02-2024, 10:11 PM | #11 |
Location: North Warrandyte, Melbourne,Victoria, Australia
Do you have the Ford part numbers for the bearings?,
My Timken catalog 1945-1961 lists these Timken part numbers: 1948-F1-8HC, 8RC, Rear wheel inner: cone 3984, inner cup,3920, ,Rear wheel outer: 462 cone, 453X cup, Rear wheel inner cone: 18790, Rear wheel inner cup 18720, Rear wheel outer cone 18690 cone, 18620 cup, Rear wheel inner cone: 368A, cup,362A, Rear wheel outer cone: 359S, cup, 354A. |
01-02-2024, 10:32 PM | #12 |
Timken 514003=88128 made by: BCA/ FAFNIR (now Timken), FEDERAL, NDH, L&S, FAG, INA, SKF, &well known reputable japanese bearing manufactuers.
01-03-2024, 02:03 PM | #13 |
Got'er figured out boys, thanks! The diff setup came out great! Thanks for the help!
01-03-2024, 02:16 PM | #14 |
01-03-2024, 05:12 PM | #15 |
The Mercury 8M-1225-B part number is one of the common numbers for the Dana 41/44 outer axle shaft bearings. They are ball bearings that utilize a race retainer sleeve. Ford developed a new part number in 1952 that was 2C-1225-A and it mentions using those in muddy environments since they have better seals but they are interchangeable.
A person needs the Ford truck chassis parts catalog to find parts for the F1 pickup. The Dana 44 changed a bit in 1950 and then again for the F100 pickups in 1953 but a lot of parts are interchangeable. The Mercury rear axles used from 1949 through 1951 have different spring pads but are otherwise the same. Last edited by rotorwrench; 01-03-2024 at 05:18 PM. |
