Old 12-28-2023, 10:07 PM   #1
Mike1291
Mike1291's Avatar
Default Zenith will flood the engine constantly
I have a Tillotson on my stock engine that been giving me some trouble. Fortunately, I have a Zenith-2 I can use that was rebuilt, albeit 30 years ago.
I thought that I'd try and put it on for the heck of it and the car does idle and rev nicely. However, the moment I start going down the road the car starts to putter out and dies. The only way to restart it is to open the throttle all the way and crank until it roars back. It also leaks gas from something other than the fuel line. I'm guessing that the car is flooding itself somehow.
I should probably give it all new gaskets based on the age of the rebuild, but I wanted to check the carb out and do a few tests. I found out the following:
-The float does not leak after submerging it in gas for several hours
-The float valve does not leak if I blow into the gas line inlet and press on the ball lightly
-The float is set properly (using Paul Shinn's inversion trick shows that the float is at the correct height).
-The main and cap jet do not leak gas if you leave gas in the carb bowl at the correct height (5/8 from gasket)
-The carb adjustment needle DOES, however, have gas pool in the cavity after where it and the carb driver meet if you leave gas in the carb bowl at the aforementioned height
Does anyone have any ideas/suggestions of what I should look for next?
Mike1291 is offline   Reply With Quote
