Old 12-17-2023, 11:51 AM   #1
KMBeers
KMBeers's Avatar
Default Valve adjustment tools
I am gearing up to remove my valve cover and check and reset as needed the clearance on the valves. I want to make sure I have everything I need before I start the project so the only question I have is what wrenches are needed to make the adjustments and do they need to be narrow or can standard ones be used? Any help or advice is appreciated.
KMBeers is offline   Reply With Quote
