12-14-2023, 03:11 PM | #1 |
Installing firewall insulation pad 36 p/u
Does anyone have any tips for getting the molded part of the insulation pad up into the firewall. I cant seem to get around the gearshift steering column and e brake.
12-14-2023, 04:19 PM | #2 |
Re: Installing firewall insulation pad 36 p/u
'32 we assemble separately first, '33 on we assemble with all those 'sticks' removed. Newc
12-14-2023, 04:52 PM | #3 |
Hmmm. I am having a problem visualizing "gear shift steering column and e-brake" in a '36 pickup.
Are we dealing with a modified vehicle here? |
12-14-2023, 05:16 PM | #4 |
I was thinking I would try to remove “those sticks” cause that fiberglass panel doesn’t have much flex. How hard is it to take the shifter handle off?
12-14-2023, 05:29 PM | #5 |
I'm sure someone will mention it; but when installing and removing the shift lever, keep track of the guide pin so it doesn't fall inside the transmission.
12-14-2023, 06:34 PM | #6 |
12-14-2023, 06:41 PM | #7 |
Did you come in from passenger door or driver door. Mine is molded so there is very little flex
12-15-2023, 10:06 AM | #8 |
From the passenger side. Slide the shifter back into 1st gear and have the parking brake on. Is your panel fiberglass, or abs? I know both are available as replacements.
12-15-2023, 06:49 PM | #9 |
I believe it’s fiberglass
