Go Back   The Ford Barn > The Swap Meet > Wanted > Early V8
Old 04-03-2011, 09:34 PM   #1
Coupe35
Default 1933-36 Ford Clutch Brake Pedal Pad
City: Paducah
State: KY
I need one original 33-36 clutch brake pedal pad, part number 40-2454 in good condition. The original pad has a taper thread and not straight thread. Will purchase a pair if you do not want to sell seperate. Please send price and picture to: [email protected]
Coupe35 is offline   Reply With Quote
Old 04-04-2011, 08:10 PM   #2
JM 35 Sedan
JM 35 Sedan's Avatar
Default Re: 1933-36 Ford Clutch Brake Pedal Pad
The straight thread pedal pads will work ok but they screw down further than the original tapered thread pedal pads. What I do to make them work better is put a spacer and a large lock washer between the pedal pad and the threaded arms so they stop in the correct position and stay there because of the lock washer.
John
