11-15-2023, 02:11 PM | #1 |
Mystery Blower
Does anyone know what this is and goes to. Came with a bunch of flathead parts that I purchased long ago. Does it have any value. Looks to be in great condition.
Thanks, Rick |
11-15-2023, 02:57 PM | #2 |
Re: Mystery Blower
Not of any use for a Ford flathead. The blower is from a modern production car possibly a V-6 since its small compared to what's used all newer V-8 engines.
This type of modern screw blower is what's know as dry this means no gas gets between the rotors only air. That odd looking opening in the rear of the case is where the air enters. The gasoline enters below the blower into the intake manifold by way of electric injectors the air from the blower rotors and the gas then combine to feed the engine. This arrangement is what's used on every supercharged production car on the market today and for a few decades now. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
11-15-2023, 03:32 PM | #3 |
Re: Mystery Blower
Thanks for the knowledge. The V belt pulley is what made me think it was for an older installation. I've had it for many years not knowing anything about it.
11-15-2023, 03:51 PM | #4 |
Re: Mystery Blower
I think its for a 3.8 6 cyl GM . Pulley was changed
11-15-2023, 04:08 PM | #5 |
Re: Mystery Blower
For what it's worth, I seem to remember a thread on the H.A.M.B. several years ago where someone used one of these "rear input" blowers on his build. I remember that it looked a lot like the one in your picture, but I could be way off because it was a while ago. If you have some time to spend, you may want to look for the thread over there. (The "Search" function over there works a lot better than the one on this forum.) If I remember correctly, whoever it was figured out a clever way to get around the odd inlet location.
EDIT : You might start here : https://www.jalopyjournal.com/forum/...mount.1050813/. Last edited by tubman; 11-15-2023 at 04:20 PM. |
11-15-2023, 05:58 PM | #6 |
Re: Mystery Blower
11-15-2023, 06:44 PM | #7 |
Re: Mystery Blower
E9 prefix would be 1989 so Thunderbird Super Coupe 3.8L V6.
11-15-2023, 08:03 PM | #8 |
Re: Mystery Blower
I seem to remember some flathead manifolds for these; Off shore builds. Newc
11-15-2023, 09:49 PM | #9 |
Re: Mystery Blower
11-15-2023, 10:04 PM | #10 |
Re: Mystery Blower
Man!! You may have uncovered a real gem. Here. If it was me, I would graciously prevail upon the great "Ol Ron" to help quantify the nuances and historical relevance of this piece. This was his " Grand Stage". He is so very knowledgeable but even more important, he is so gracious with his time.
The problem with blowers etc. in these flatheads, there is a limit to modifying them to the point of irrelevance. My opinion. I admire those who can get the most with the least in these engines. To modify these engines, much beyond the initial engineering genius levels established by Ford's ground breaking engineering department, takes the fun out of it. FH's don't breath. It's a wonderful Thing!!! That gives us all a challenge. Feed the engine as instructed on the label. |
11-16-2023, 02:30 PM | #11 | |
Re: Mystery Blower
I'm So Confused
11-16-2023, 02:47 PM | #12 |
Re: Mystery Blower
If anyone is interested in this blower it's free as I have no use for it, just pay shipping from Miami, Fl 33157 Package will be 20X9x7 inches and weight 25 Lbs. Will probably cost over $30 Email me at [email protected]. Mention Blower in subject line
Will post it later on swap meet |
11-16-2023, 03:25 PM | #13 |
Re: Mystery Blower
Sorry, I guess my position is that with too much modification (I do not consider a blower as too much) these engines cease to be flatheads and become something else. I like the old tinkering. Add a carburetor, mill a head, punch up the cam. etc. Help it breath.
11-16-2023, 09:06 PM | #14 | |
Re: Mystery Blower
Ronnieroadster
11-16-2023, 09:38 PM | #15 |
Re: Mystery Blower
11-17-2023, 04:28 AM | #16 |
Re: Mystery Blower
Sorry for the rant. To offer an answer for your inquiring mind, the Ardun conversion first comes to mind. "Let's kill the flathead and convert it to a SBC." Why? You want a SBC? Hows about yous go on down to Bubba's Salvage Yard and Bait Shop and buy one.
11-17-2023, 05:10 AM | #17 |
Re: Mystery Blower
This should be interesting. Ronnie, I'll start making the popcorn....
11-17-2023, 09:07 AM | #18 |
Re: Mystery Blower
Not an SBC; maybe an early Dodge (241/270 ci) hemi?
11-17-2023, 10:00 AM | #19 |
Re: Mystery Blower
47topless--Thanks for the laughs!
11-17-2023, 10:05 AM | #20 |
Re: Mystery Blower
Thank you. Just doing what I can to have a little fun.
