Old 11-14-2023, 11:55 AM   #1
drgoetz
drgoetz's Avatar
Default 49-51 Merc Speedometer Removal
I have a '50 Merc with a speedometer that does not work. I replaced the gear and the cable; the "speedo" part worked however the odometer does not move. I can hear the cable. Additionally, at present, NOTHING WORKS.
I have made attempts to remove the dash with no luck. I can only get it part way out and then the wiring harness and steering wheel prevent any further movement. I have dropped the steering column out of its bracket, however, the wiring harness is so brittle I fear the cloth coverings will crack and "short" the dash.
I did try to remove the speedometer from the back/bottom but the peddles beat-me-up.
Any suggestions other than letting "someone else do it"?
drgoetz is offline   Reply With Quote
