11-07-2023, 03:09 PM | #1 |
removing wiper motor
How is the knob attached to the wiper motor rod?
Thanks guys...
11-07-2023, 04:35 PM | #2 |
Re: removing wiper motor
Is this a TRICO vacuum unit?.
11-07-2023, 04:59 PM | #3 |
Threaded
www.whidbeymodelaclub.com |
11-07-2023, 05:02 PM | #4 |
I don't know if all the model A type trico motors used the same set up but a lot of them did screw onto the control plate or rod depending on type.
Electrical types in 28 through early 30 were a completely different set up. A lot of commercials just had the manually operated wiper set up. |
11-07-2023, 05:04 PM | #5 |
Hmmmm.... how can I determine this?
11-07-2023, 06:57 PM | #6 |
11-07-2023, 07:31 PM | #7 |
nevermind
11-07-2023, 08:42 PM | #8 |
I should look like this.
11-07-2023, 09:31 PM | #9 |
MAFCA has a pdf file on wipers for the model As. It has all the info a person needs for the different years and types. If you Google it, it should come up.
Ford started to use TRICOs on commercials in early to mid 1930. Before that, they were all hand operated. |
11-10-2023, 03:26 PM | #10 | |
I got it, finally
