#1 |
Last week while heading down our steep gravel road in first gear, the floor shift knob started vibrating badly and there was a loud clicking or ratcheting coming from the transmission area. There were no previous indications of this condition. This truck is the one I converted to a woodie wagon a few years back. I got us turned around and the noise/vibration was not evident going back up the hill. Later that day I pulled the driveshaft and checked the splines and u joints. Splines were perfect and showed almost 3" of engagement. The u joints were also in good shape. I finally got a chance to drive the vehicle quite aggresively today and the sound is very pronounced in decelleration and non existant in acceleration. Another important factor is this problem only exists in first gear. Second, third and reverse operate as before. While I have completely overhauled six or seven flathead V8s and all manner of other repairs on the V8 trucks, I have no experience with transmissions. Is it time to pull this 3 speed and open it up? (I have all winter). Could this be something more external? And lastly I have been considering a T-5 swap as my tall tires, hilly island environment, stock 221 engine and heavy vehicle have me longing for a lower first gear. With open driveline, maybe the T-5 swap is pretty straighforward? Thanks in advance, GB
#2 |
countershaft thrust washer is worn out--these trans are not very "backdownable" very weak thrust washers on counter shaft. does not do it in reverse because the thrust is in the other direction on the counter shaft
#3 |
If you do decide to rebuild what you have I highly recommend Mac Van Pelt's book on rebuilding these transmissions. It was a big help to me when doing my first. He is also an excellent source for spare parts.
#4 |
Super Moderator
I tend to agree with Alan in regard to the most probable cause.
I agree with Sidevalve in regard to obtaining that book. These transmissions are NOT tough to rebuild at all. With what I'd witnessed of your exploits, you'll soon be wondering why you may have had some hesitancy to tackle this. You CAN handle this.
#5 |
When you had the driveshaft out did you happen to check for end play in the mainshaft?
Regards, Paul |
#6 |
#7 |
No, I didn't. Just wiggled up and down and very little play if any.
#8 |
My 'new' mechanic shop.
#9 |
I agree that you will have no trouble rebuilding your transmission. About 30 years ago when I was building my '36 3 window, I wanted a good reliable transmission to go behind the 276 ci flathead I was putting in it. I bought a '39 transmission off of Hemmings, a good '46-'48 transmission locally and all the NOS small parts (bearings, synchronizers, etc.) I could find. I also had an early Ford transmission book I got somewhere. After reading the book about three times, I got to work. I was careful and ended up with a transmission that was virtually perfect.
Long story short, I had almost no experience going in and got very good results. For a guy with your skills, it should be a "piece of cake". |
#10 |
You should have no problems rebuilding an old Ford transmission. I have to ask, if you are contemplating a transmission swap to get a lower first gear why not go with a 4 speed crashbox? They made half ton rear mounts for them and are usually free when you find one.
#11 |
#12 | |
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) Last edited by GB SISSON; 11-05-2023 at 09:46 PM. |
#13 |
Does your 3 speed have the 25 tooth cluster gear? If not, that might be a good option to get lower first and second gears.
My mistake!! Should have said 29 tooth cluster. (Thanks Tim!)
Don't never get rid of nuthin! Last edited by PeteVS; 11-07-2023 at 09:35 AM. |
#14 |
Sounds like something to look into for sure. Just the kind of thing I will be researching. Thanks much. Highest speed limit here is 40 on one of the few straightaways. We have taken the woodie to the mainland 3 times since building it, and only once on the interstate, so you can see my needs are different than most of today's drivers of early fords.
#15 |
Gary, I'm probably finished with my transmission rebuilding projects. If you can use a copy of Mac VP's book, send me a PM for your mailing address and I'll send it to you it off to you with my compliments....it was invaluable to me when I rebuilt my '47 side shifter!!
![]() Regards....Dick |
#16 | |
Thank you ever so much!
#17 |
Does anyone have the specs on this 25 tooth cluster gear? I'm guessing I have the higher geared version. This could be a great solution. Edit: Looking at the VanPelt site, the chart seems to indicate the higher tooth (28) on first of the cluster results in a lower first and second. It also reminds me that there was a HD 3 speed for trucks with a low in the mid 3's, and a synchro 4 speed from '48-'64. These options could be very rare I'm thinking.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) Last edited by GB SISSON; 11-06-2023 at 12:43 PM. |
#18 |
Maybe I missed something, but the 25 & 26 tooth clusters were found in Lincoln Zephyr transmissions. These were Ford's version of a wide ratio transmission and used to help move those heavy Lincolns down the road. Most of these LZ's had a 4.33 rears (I believe, not a LZ expert) with an O/D transmission and possibly a Columbia as well.
I'd doubt GB's transmission has a set of LZ gears in it, but you never know. If this is going behind your 221 and your top speed is going to be 40 mph, I think you'd be much happier with a 28 tooth gear set with 3.78 rear end ratio. Can't recommend Mac VP's book enough and agree you can handle this job without issue. If you are going to give this trans a "refresh", I'd suggest going with the improved synchro set up found in mid to late '39-'48 Fords. I've found 40-48 side shift transmissions to be excellent donors for good gears and other parts. You'll need a 81A double detent top with 91A forks to work with the larger synchro hub. This combo will provide endless miles of trouble free cog stirring. Last edited by Tim Ayers; 11-06-2023 at 08:16 PM. |
#19 |
There is a 29T cluster gear for the three speed transmissions that will give the lowest, most gear reduction, first gear ratio. I thought it was commonly used in truck transmissions.
#20 |
The two ratios I'm familiar with for the three speed trans are 16/28 and 15/29 input gear/cluster.
A link to ratios courtesy MacVP- http://www.vanpeltsales.com/FH_web/f...gearratios.htm
"It don't take but country smarts to solve the problem" (Smokey Yunick) '30 Model A Speedster '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302
