Old 10-15-2023, 07:46 AM   #1
Ziggster
Default Rare Wide Five Rim - 15 x 6?
Picked this up last week in Hershey. Did a bit of digging and posted on the HAMB, but really didn’t find much. Stamping on rim says Kelsey-Hayes 15 x 6 L. I’ve searched the interweebs, and found 15 x 6 rims, but not in the style I now have. In particular are all the rivets along the inner portion hub circumference without any clearance holes/slots. Anyone have more info as I’m looking for another?
Ziggster is offline   Reply With Quote
Old 10-15-2023, 09:07 AM   #2
truckdog62563
truckdog62563's Avatar
Default Re: Rare Wide Five Rim - 15 x 6?
Likely a Marmon-Herrington wide five wheel. Stu
Stu McMillan
Marmon-Herringtons
truckdog62563 is offline   Reply With Quote
Old 10-15-2023, 10:07 AM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
I had one like that years ago and sold it for good bucks, since I had no use for it then, and still wouldn't today. Now if it had been a 16"x 6" wide, 5 on 5-1/2 wire spoke, straight or bent spokes, it would most likely be on one of my '35's right now
John
Old 10-15-2023, 10:23 AM   #4
truckdog62563
To determine if it is a MH wheel a call to Chuck Mantiglia is in order. Plus he might have a line on others. Stu
https://www.chuckstrucksllc.com/
Stu McMillan
Marmon-Herringtons
Old 10-15-2023, 11:05 AM   #5
Ol' Ron
Ol' Ron's Avatar
Could be an old "stock car wheel.
G
Old 10-15-2023, 11:31 AM   #6
deuce_roadster
deuce_roadster's Avatar
As Ol' Ron said, I have seen those on old stock cars that had been widened or the center put into another wheel after the original center was removed.
Old 10-15-2023, 11:59 AM   #7
Newc
Newc's Avatar
V8'er in Oregon has a set [4] For Sale with modern radials on them. Custom made wheels these are. Newc
Old 10-15-2023, 02:04 PM   #8
Ziggster
Pretty sure they are stock and have not been made wider after the fact. Other 5” wheels that I’ve found pics of on the web look different and are typically 16”. From what others have said, and from more researching on the interweebs, the 15” x 5” wide five wheel, would have been made by Kelsey Hayes, and used specifically on Ford 4x4 truck conversions done by Marmon-Herrington.
File Type: jpg 9ED6023D-687D-41B5-BD3D-045BBB5DFFBB.jpg (30.8 KB, 20 views)
Old 10-15-2023, 02:31 PM   #9
Ziggster
Did find this thread on the HAMB, and his wheels looks just like mine. First pic, I’ve come across that has the same rivets around the inner portion with the accompanying “dimples” for the rivets.
https://www.jalopyjournal.com/forum/...wheels.849665/
File Type: jpeg D1DE9CB3-532D-466F-B01F-BBC3E68007C0.jpeg (131.7 KB, 294 views)
File Type: jpeg 3212FBF5-649A-469C-A0DB-5C3C9E71DAF1.jpeg (126.9 KB, 296 views)
File Type: jpeg 3B08B033-00ED-4FFF-AB88-55FC0FD83A44.jpeg (107.9 KB, 293 views)
Old 10-15-2023, 02:57 PM   #10
Ziggster
Apparently, this is the part number. Post #14 in the thread.
https://www.jalopyjournal.com/forum/...l-tech.115542/
File Type: jpg 673FEACD-4631-48D9-8EE7-8F72D13021A8.jpg (36.9 KB, 19 views)
Old 10-15-2023, 03:05 PM   #11
petehoovie
petehoovie's Avatar
Old 10-15-2023, 04:18 PM   #12
truckdog62563
That number is close, but wrong. A K28028 is a hub cap used by Olds and Pontiac. The correct number is K28025. Described as a 15” x 6” with wide five pattern and listed as used 1936 to 1939. And later no doubt since MH was known for using stuff way longer than the application called for. This is the only early pattern 15” x 6” K-H lists. Sold as a set in #1531L. The 4/42 M-H LD6-4 manual has it assigned their number LD1-5368. Stu
Stu McMillan
Marmon-Herringtons
Old 10-15-2023, 04:44 PM   #13
Ziggster
Amazing knowledge there Stu! There is what appears to be a “57” embossed next to the “15 x 6 L”. What would that indicate?
Old 10-15-2023, 04:57 PM   #14
truckdog62563
Not knowledge, a good reference library. I kinda doubt that KH would have the NWRA kit number on a wheel, especially since they never ever stamped their own part numbers into their wheels. Since my above post I found two other NWRA sources that list the 1531L for the size and width of this wheel. Stu
Edit - sorry I don’t know the answer to your question about the 57. The other graphics are the logos used by the NWRA to designate the type of vehicle application. Stu
Stu McMillan
Marmon-Herringtons
Last edited by truckdog62563; 10-15-2023 at 07:48 PM. Reason: Typo on the kit number
Old 10-16-2023, 08:24 AM   #15
Seth Swoboda
Seth Swoboda's Avatar
Are those V8 60 wide 5's?
Seth Swoboda is offline   Reply With Quote
Old 10-16-2023, 08:49 AM   #16
truckdog62563
If that was a question for me, sorry I don’t know except to repeat that they were listed as applying to 1936 to 1939 Commercials. The Green Bible doesn’t list them, and the LD6-4 M-H manual only describes them as being used with 7.50”, 8.25”, and 9” tires. Would a V8 60 handle rubber that big? Stu
Stu McMillan
Marmon-Herringtons
Old 10-16-2023, 08:52 AM   #17
nelsb01
nelsb01's Avatar
NO..............60 hp wide fives were constructed just like the 85 hp wide fives manufactured by FoMoCo. Just with narrower width.
These look like a special manfacturing.
nelsb01 is offline   Reply With Quote
Old 10-16-2023, 09:00 PM   #18
38 coupe
38 coupe's Avatar
I had a set of 1941 Ford 3/4 ton wheels and they are wider than normal Ford wide 5 pattern wheels. At one point when I was very young, in the 1980s, my dad had a set of 15" wide five pattern wheels and they also looked like the 3/4 ton wheels I had until recently. I highly suspect the 15" wheels dad had were M-H in origin. Both the 3/4 ton and the 15" wheels had centers with four areas that riveted to the hoop, like a normal 1940 Ford wheel. Neither set looked like the wheels at the beginning of this thread. I'm confident those wheels are aftermarket, most likely old racing wheels as suggested by Ol' Ron and deuce_roadster.
Old 10-16-2023, 10:06 PM   #19
JM 35 Sedan
No way Seth. 60hp wide 5 wheels are 3-1/2" wide where the tire locates on the rim. I have a bunch of those that came off 60hp, 37 Fords.
John
Old 10-16-2023, 11:57 PM   #20
deuce lover
deuce lover's Avatar
3.5" wide fives were also on all 1936 Standards,Deluxe were 4".
deuce lover is offline   Reply With Quote
