10-11-2023, 04:56 PM | #1 |
Reduction Ratio Gear End Cap Removal
I have the reduction ratio gear end cap off my 31 roadster. I need to get the gear shaft out to inspect it. How do I pry the end cap off without destroying it? Is there a trick to it?
Kevin Essex, CT |
10-11-2023, 05:09 PM | #2 |
Re: Reduction Ratio Gear End Cap Removal
What component are you referring to?
10-11-2023, 05:30 PM | #3 |
The cap on the end of the reduction gear.
Kevin Essex, CT |
10-11-2023, 06:46 PM | #4 |
Are you asking about the speedometer drive?
10-11-2023, 07:18 PM | #5 | |
www.whidbeymodelaclub.com |
10-11-2023, 07:23 PM | #6 |
10-12-2023, 06:44 AM | #7 |
This is the Reduction gear (I think its a.k.a "Turtle").
Kevin Essex, CT |
10-12-2023, 10:08 AM | #8 |
I use a small flat blade screwdriver and work my way around it prying it a little at a time. Might be good to soak in solvent for a while first if it doesn't want to come out.
