Old 10-08-2023, 05:52 PM   #1
BobR35
BobR35's Avatar
Default 12V access alternatives
Since I purchased my '35, 3 years ago and realized that I needed some 12v accessories, headlight to see the road at night, 3rd tail light in the rear window, and a USB port, I found a converter that worked and then I was hard pressed to find a way to mount it. FYI, I was able to make a fuse panel and mount it under the dash. It actually works pretty good, doesn't show and doesn't interfere with any original equipment. I was just wondering if there was any other ideas that was out there and what you did if you did?
BobR35 is offline   Reply With Quote
