#1 |
I'm trying to help a friend clear out a garage. There is a set of 4 doors that we can't identify. Someone suggested that they might be from a 1940 Ford. I'd appreciate your expert opinions about what they came from.Thank you.
#2 | |
#3 |
Look like '40, trim is '40. Fronts can fit a cpe with slight Modification. Rears ??? value. Newc
#4 |
Look for bug marks on the glass . It should be a date and manufacturers mark.
#5 |
Super Moderator
1940 Ford fordor sedan. As has been mentioned, the front doors can be modified to use on a coupe.
#6 |
#7 |
Thank you all for your help. I should have known to look for the bug, but it never dawned on me. But I wasn't sure they were Ford parts either. I am a truck guy. They will be available sometime soon. Steve
#8 |
Steve, if the glass is original FoMoCo there should be "bugs" as already mentioned in two posts. From what I can see in your pics, they look to be in good condition with the front doors probably being the the most valuable of the four.
