Old 10-01-2023, 02:50 PM   #1
Terry, NJ
Terry, NJ's Avatar
Default Casting Numbers REPUBLIC B140 Flywheel cover
Just acquired a new (Sorta) Flywheel cover with these numbers and no visible cracks. It's rusty as hell and requires a lot of wire brushing. Who is/was REPUBLIC? Was Ford using this name for some reason ? Or was Ford subbing out some of the casting work?
Also, should I pay someone with a Blanchard or a Blanchard type grinder to kiss off the mating surfaces ? As I said, this thing is is rusty as hell and the mating, surfaces are are distorted. And parallelism ????????. How much can you take off a F W. cover safely ? Thanks in advance!
Terry
Terry, NJ is offline   Reply With Quote
