09-21-2023, 03:19 PM | #1 |
Dixson Tach Dwell tester
I picked this up at a junk store and haven't found directions on search. Just others for sale. I'm dialing in the H six and would like to play with this. I'm 12 v neg ground. What wire where? Thanks.
09-21-2023, 04:08 PM | #2 |
Re: Dixson Tach Dwell tester
If it works like mine, red on the distributor side of the coil and black to ground. If it is 6V positive ground system, you might have to reverse them. I've not used one on a positive ground system.
09-21-2023, 04:12 PM | #3 |
09-21-2023, 08:10 PM | #4 |
That’s a model 1501. Bruce Dixson was the owner of Dixco…. they manufactured tachs and test equipment for cars. They were acquired by an OE automotive electronic supplier around 1987 I think. I doubt they provide access to the old manuals though, even if you could find the company that bought Dixson.
I’m guessing that obtaining a copy of that particular manual might be difficult…. Compared to getting one for say a Dixco hood tach. |
09-21-2023, 10:50 PM | #5 |
The RPM function I want for adjusting idle and timing. Dwell I have never dealt with. Used for setting points? I have used a feeler gauge for 54 years and then set the timing by ear. But now the subject interests me more. I bought an old craftsman inductive timing light a couple years ago at a yard sale. Before that I never used one. So for dwell I look up my specs and see if my needle reads at that spec. If not I open or close the gap to suit?
09-22-2023, 08:30 AM | #6 |
Dwell is measured by connecting the red lead to the coil (-) terminal, the distributor side, and connect the black lead to ground. A dwell meter is actually a voltmeter, and it's reading an average of the points-open voltage (full charging system voltage) and zero volts when the points are closed. It's expressed in "degrees of dwell" since a set of points that stay closed (dwell together) all the time would be 60 degrees of distributor rotation, and open all the time would be zero degrees of dwell. A 66% dwell reading would be 40 degrees on a 6-cylinder engine.
Making the simple complicated for over 30 years. |
09-22-2023, 11:41 PM | #7 | |
