Old 09-13-2023, 04:20 PM   #1
crjohn
Default Adding a ballast bypass starter solenoid???
I am working on my 1947 super deluxe. I have decided to stick with the original 6V positive ground system. I have noted that the ballast resistor is not bypassed when starting, this came as surprise to me??? Has anyone switched to a four terminal starter solenoid with the option to bypass the ballast resistor when starting? If so did it help starting or cause any unexpected problems?
Thanks for any input!
CRJOHN
crjohn is offline   Reply With Quote
