Old 09-03-2023, 02:38 PM   #1
38convsedan
38convsedan's Avatar
Default What aftermarket Jack do you use?
For those of us not having a correct issue Ford jack, wondering what aftermarket jacks Barners are using.
As always, thank you in advance!
38convsedan is offline   Reply With Quote
Old 09-03-2023, 03:27 PM   #2
cadillac512
cadillac512's Avatar
Default Re: What aftermarket Jack do you use?
I'm using one of these. Works well and the handle they offer is at least 6' long and reaches out to where you can operate the jack easily. Good quality.
https://armysurpluswarehouse.com/scissor-jack-style-2/
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 09-03-2023, 03:35 PM   #3
Krylon32
Since mt first old car in 1970 I've never carried a jack. Probably been lucky. Lately since I've got the 40 standard coupe with a trunk big enough to camp in I've been carrying a small aluminum floor jack with a 4.5 ft handle that will go under almost anything, lift high enough and has a nice rubber pad on the lift area. When I'm traveling in my deuces I make sure I have the 800 number of AAA and my cell phone for a rescue if needed.
Krylon32 is offline   Reply With Quote
Old 09-03-2023, 04:45 PM   #4
J Franklin
J Franklin's Avatar
A small bottle jack is easy to carry so that is what I use.
Old 09-04-2023, 10:28 AM   #5
1931 flamingo
1931 flamingo's Avatar
AAA
Paul in CT
Old 09-04-2023, 01:44 PM   #6
J Franklin
J Franklin's Avatar
Talking Re: What aftermarket Jack do you use?
Originally Posted by 1931 flamingo View Post
AAA
Paul in CT
Cheater!
Old 09-04-2023, 11:46 PM   #7
Brian
Brian's Avatar
if you have a 39 Merc, you need a bumper jack in order to be able to remove a rear wheel.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 09-04-2023, 11:51 PM   #8
Newc
Newc's Avatar
Remember some later Fords have such tight rear wheel wells, that they have to go WAY up for a change. Very shaky. 49-53, I'm thinking. Newc
Old 09-05-2023, 08:02 AM   #9
Kurt in NJ
Kurt in NJ's Avatar
My 46 i got in high school came with a 36 flip top jack and 3 piece handle, I used that on many cars, now it’s part of the 36 toolkit
Old 09-05-2023, 08:14 AM   #10
Planojc
Planojc's Avatar
scissor jack from Northern tool.
Planojc is offline   Reply With Quote
Old 09-05-2023, 09:00 AM   #11
nelsb01
nelsb01's Avatar
A scissors jack from a Ford Windstar van. All the pieces, handle, jack and lug wrench fit together. Just add a 1 by 6 board for a base to set it on.
Lifts my 1949 Ford rear using it on the frame (not the axle) high enough to remove the rear wheel from the fender over hang.
Cheap item from your local vehicle recycling yard. (formerly called junkyard).
nelsb01 is offline   Reply With Quote
Old 09-05-2023, 10:50 AM   #12
19Fordy
19Fordy's Avatar
If you use a scissors jack weld or bolt a larger base to it for stability.
Old 09-05-2023, 11:36 AM   #13
51504bat
51504bat's Avatar
Maybe one of these but only 12 volt.
https://www.amazon.com/VEVOR-Electri...BoChGgQAvD_BwE
Old 09-05-2023, 11:47 AM   #14
tubman
tubman's Avatar
Originally Posted by 51504bat View Post
Maybe on of these but only 12 volt.
I never knew that anything like that even existed.
Another reason for us old guys to convert to 12 volts.
Old 09-05-2023, 11:59 AM   #15
petehoovie
petehoovie's Avatar
