Old 08-31-2023, 04:35 PM   #1
Terry, NJ
Terry, NJ's Avatar
Default I've got a problem!
So I'm working on a 1930 Coupe engine. It's pretty much stock except for a .040 oversize, and police head. I don't know the mileage on the engine, but it's well over 10K, probably about 25 K. Famous words, "It was running when I parked it!" I had another engine I had fixed up with new mains ($700) but it was noisy so I put the old mill back in her. OK I tried to start it a few day ago anti wouldn't start (no spark) but I never saw an engine hop around (Chassis and all) like this. Today, I Was going to remove the distributor and I was going to put the pin in position and I tried moving the crank and it seems to be locked. No Go! I can sort of guess what happened, but How? Yeah I know it was out side, but it was always covered with at least two tarps, plug holes were plugged and oiled so I doubt it was the cylinders. No I believe it was the center main disintergrating and the pieces packing up and jamming the crankshaft. Either way, I'll probably have to pull the engine which I am not liking. 79 YO this july and I want to get this one done! If anyone has any other scenarios, please post. Thanks!
Terry
Terry, NJ is offline   Reply With Quote
Old 08-31-2023, 05:10 PM   #2
Flathead
Flathead's Avatar
Default Re: I've got a problem!
Drop the pan for a look-see?
Flathead is offline   Reply With Quote
Old 08-31-2023, 05:54 PM   #3
gdmn852
gdmn852's Avatar
Hello,a long time ago, a friend bought a Model A that was turned into a tractor for the engine. Could only get it to run on 2 cylinders, took off head and found 2 compressed mouse nests , apparently crawled in from open valves .
gdmn852 is offline   Reply With Quote
Old 08-31-2023, 07:17 PM   #4
nkaminar
nkaminar's Avatar
Take the head off and drop the pan to see if there is something that can be done while the engine is in the car. But I am afraid you will have to pull it. Maybe you can make one good engine out of the two. Could be a mouse nest as described in post #3.
Old 09-01-2023, 06:36 AM   #5
midgetracer
midgetracer's Avatar
Wild idea, but could the starter just be locked on the ring gear. I have had that happen several times.
midgetracer is offline   Reply With Quote
Old 09-01-2023, 08:13 AM   #6
Planojc
Planojc's Avatar
Put it in gear and rock it, see if the fan will turn.
Planojc is offline   Reply With Quote
Old 09-01-2023, 08:15 AM   #7
deuce5wndw
deuce5wndw's Avatar
Did you try turning it without the plugs? Maybe water got in the cylinders through head gasket or?
deuce5wndw is offline   Reply With Quote
Old 09-01-2023, 08:51 AM   #8
WHN
Start by pulling the head. Then I would work forward from there, pan, ect.
Good luck.
WHN is offline   Reply With Quote
Old 10-01-2023, 03:49 PM   #9
Terry, NJ
Terry, NJ's Avatar
Well guys, I thought I'd update this and maybe have a teachable moment too. I Knew that engine was loose! I did! However, I had to disconnect it from the driveline to find out how it really was. I pulled the engine and t was fine, something is locked up in the , I believe, the trans. Frankly, it's acting kind of weird, it acts like it's in two gears at once! Anything is possible I guess! The I cracked the fly wheel housing. No actually it broke! I very gently tapped it a piece with old rusty, crack lines dropped off the bottom. More about that in my thread about REPUBLIC B140.
Terry
Old 10-01-2023, 04:52 PM   #10
Richard Knight
Well Terry, isn't there anybody near that can help you. I am 75 and changed three motors in the last year. It is a lot harder than it used to be and I have the right tools. The trans probably is in two gears which is easy to fix.
Richard Knight is offline   Reply With Quote
Old 10-01-2023, 06:36 PM   #11
Gene F
Gene F's Avatar
But don't start the car with the top off of the transmission! It slings grease every where, even with the clutch in.
Gene F is offline   Reply With Quote
Old 10-02-2023, 08:53 AM   #12
Bob Bidonde
Bob Bidonde's Avatar
I feel your pain being a pleasantly plump 80 year old. Here on Long Island we have work parties we call "Play Dates" to help each other get the big jobs done. Call up 2 or 3 knowledgeable club members, provide coffee, donuts and a pizza lunch, and get the work done while having friends to talk to. You give some payback by joining a work party for someone else.
Bob Bidonde
Old 10-02-2023, 09:35 AM   #13
Fullraceflathead
Fullraceflathead's Avatar
You can buy a small borescope that will fit into an iPhone for under $10 you can inspect inside the cylinders and also inside the crankcase without doing major tear downs.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
