Old 08-29-2023, 11:49 AM   #1
FwJ1941
Default Wire Harness
I’ve a 1941 Ford 1/2 Pickup and would greatly appreciate consensus on which vendor you recommend to explore purchasing a complete wiring harness to replace existing. After 80 plus years, it’s time. The electrical system has been converted to 12 volt system otherwise I believe it to be original. Sincerely appreciate your recommendation.
Thank you!
Frank W Jonex
FwJ1941 is offline   Reply With Quote
Old 08-29-2023, 12:39 PM   #2
ssffnomad
ssffnomad's Avatar
Default Re: Wire Harness
Bauer Electronics
Chris Olsen
541-389-7755
ssffnomad is offline   Reply With Quote
Old 08-29-2023, 01:33 PM   #3
rockfla
rockfla's Avatar
Rhode Island wiring (401) 789-1955 IF you are wanting concourse correct.
Old 08-29-2023, 01:43 PM   #4
mrtexas
mrtexas's Avatar
If you don't care about looks get a hot rod EZ harness, all wires are marked and turn signals included.
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 08-29-2023, 01:53 PM   #5
51504bat
51504bat's Avatar
YnZ's Yesterday's Parts
Wiring Harness Catalogs | YnZ's Yesterday's Parts (ynzyesterdaysparts.com)
Top notch and they can customize it according to your needs such as turn signals.
Old 08-29-2023, 02:53 PM   #6
rotorwrench
rotorwrench's Avatar
Bauer used to only sell to parts sources. I didn't know that they sell direct. Most sources sell their products. Rhode Island Wire coats their wire to protect it from fade of the colors.
Old 08-29-2023, 04:32 PM   #7
expavr
expavr's Avatar
X’s 2 for Y n Z. They added the turn signal circuit in the harness on the Tonner.
expavr is offline   Reply With Quote
Old 08-29-2023, 05:03 PM   #8
deuce_roadster
deuce_roadster's Avatar
My vote also for Bauer like ssffnomad. Chris will make it any way you want, Dearborn correct, turn signals added, or custom like on my 32 5w, running a 59 series engine and put a Vreg on the passenger side of the firewall. I have 2 40s, and a 32 5w with Chris's harnesses, everything fit, 2 Dearborns with the my 40 wagon. Never a problem. He is also not that far from me and is very prompt about shipping stuff out.
Old 08-30-2023, 12:51 PM   #9
FwJ1941
Thank you so very much for all of your input. Great info that I’ll use to make a selection.
The info you provide is of value to us newbies.
Frank W Jones
41 Ford 1/2 Ton Pickup ��������
Old 08-30-2023, 03:13 PM   #10
swoopNZ
MEMBER EMERITUS
Tyree Harris.
swoopNZ is offline   Reply With Quote
