Old 08-18-2023, 07:41 PM   #1
Barnwood
Default 1931 Radiator
I have a 1931 slant windshield Model A. I have the radiator in the attached pictures. I don't know if it's the correct radiator for my Model A. I believe this is a 1932 radiator. Did they put 1932 radiators in 1931s?
On the inside, the top is curved. Also on the inside there are two brackets on the very top. I don't know what the brackets are for.
On the front, the top jets out. Also on the front, the fins are dimpled.
The height is 22 1/4"
The width is 17 7/8"
The depth is 2"
Do you know if this is the correct radiator for my Model A? If not, what is the correct one?
https://ibb.co/GQj44Jv
https://ibb.co/KVMt2Kd
https://ibb.co/sgZWNM6
https://ibb.co/TLrT3cg
https://ibb.co/2WJbZVd
Barnwood is offline   Reply With Quote
Old 08-18-2023, 10:21 PM   #2
Randy in ca
Randy in ca's Avatar
Default Re: 1931 Radiator
You're correct in that the one pictured is for 1932 Model B - 4 cylinder. That's all I can tell you.
If anyone else is wondering, you have to click on a very, very small image to enlarge and make viewable (at least I had to).
Randy in ca is offline   Reply With Quote
Old 08-19-2023, 12:39 AM   #3
Ramman
Barnwood, where are you located? I have a good, clean used 30-31 radiator in Northwest Ohio. PM me if interested.
Ramman is offline   Reply With Quote
Old 08-19-2023, 01:14 PM   #4
Charlie Stephens
It is definitely a '32, 4 cylinder radiator. The top extends out into the '32 shell. The Model A shell will not fit. The water neck is also in a different location. Sell it (don't try to "fix" it) and get the correct one. Where are you located?
Charlie Stephens
Old 08-19-2023, 04:35 PM   #5
Barnwood
La Crescent, Minnesota
