Old 08-16-2023, 08:40 AM   #1
HalcyonDays
HalcyonDays's Avatar
Default Battery hold down clamps
What is the best way to hold the battery down? I noticed, on the clamp that goes all around top of battery, the negative terminal clamp crosses over the top of the hold down clamp very close. I am concerned that there is potential for this terminal clamp to come in contact with the hold down clamp and short out. Is this a concern?
HalcyonDays is offline   Reply With Quote
Old 08-16-2023, 10:37 AM   #2
The Master Cylinder
The Master Cylinder's Avatar
Default Re: Battery hold down clamps
Bob Bidonde posted a picture of a battery clamp he made that works very well. I can't locate the post. I'm sure Bob will chime in.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 08-16-2023, 11:06 AM   #3
imtb
I was also concerned about the frame being so close to the battery post. I used a disc grinder and sanded some of the frame for clearance and then tapped up the frame. The battery is now locked down securely.
imtb is offline   Reply With Quote
Old 08-16-2023, 02:05 PM   #4
Dean Lemoine
Dean Lemoine's Avatar
This is the hold down I made, 12 Volt battery
File Type: jpg 30D70B8D-8B99-4E7C-AD8A-3058D9090237.jpg (60.8 KB, 168 views)
Dean Lemoine is offline   Reply With Quote
Old 08-16-2023, 06:58 PM   #5
kbinde2
kbinde2's Avatar
I bought an extra clamp/rubber bushing that routes the cable away from the pedal assembly, used the extra rubber bushing on the negative cable where it crosses in close contact to the hold-down frame. I was making replacement cables, so the rubber bushing slid over the new cable easily. If you install on existing, just slice half and it will wrap around the cable nicely.. kb
kbinde2 is offline   Reply With Quote
Old 08-16-2023, 10:02 PM   #6
al's28/33
al's28/33's Avatar
with the factory battery support bolts at opposite corners, using the full-frame hold down method I placed shrink tubing around the ends of the two battery cable clamps and have never had any issues or seen any wear thru from vibrations. 22 years and going.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 08-18-2023, 09:02 AM   #7
Patrick L.
Patrick L.'s Avatar
I just took the grinder to it.
Old 08-18-2023, 10:03 AM   #8
Bob Bidonde
Bob Bidonde's Avatar
Here is my homemade battery clamp. It is made from 5/16" diameter steel rod with washers MIG welded to each end. Besides buying the rod, you can obtain it by repurposing a brake rod, or repurposing a radiator support rod.
Bob Bidonde
Old 08-18-2023, 04:25 PM   #9
400A
I use a short length of garden hose and slip it over the battery cable and up to and over the part of the clamp that comes close to the hold down. Also watch the swap meets for the old, red plastic group 1 hold downs. They work nice and are non conductive.
400A is offline   Reply With Quote
Old 08-20-2023, 09:36 AM   #10
Russell Reay
Russell Reay's Avatar
I had the same concern. Went back to the original style hold-downs on the corners
Russell Reay is offline   Reply With Quote
Old 08-20-2023, 10:12 AM   #11
HalcyonDays
Thank you all for the ideas. It is nice to know that it is not just me. The original designed corner hold downs do not work on the new style batteries that are in my cars. The new batteries are a little smaller than what I believe were original to the car. I do agree that the corner hold downs would be my preferred solution, they just need to extend over the top of the battery a little further.
Old 08-20-2023, 11:22 AM   #12
Joop
Joop's Avatar
Steve
With your knowledge and skills you can extend the original ones.
Joop is offline   Reply With Quote
