Old 08-10-2023, 05:31 AM   #1
mmumley
Default 1936 clamshell
I have a 1936 Fordor. Reinstalling the engine. On the back of the transmission where the clamshell goes, I have two crown nuts and two normal. Should they all be crown type and should they be wired or cotter pins used to keep them secure?
mmumley is offline   Reply With Quote
Old 08-10-2023, 06:33 AM   #2
Terry,OH
Terry,OH's Avatar
Default Re: 1936 clamshell
The castle or slotted nuts (there is a difference) are on the top with cotter pins. The bottom two are special hex nuts, with a smaller than normal hex and longer in length with lock washers.
Slotted nuts are hex from one end to the other, Castle nuts are round at the slotted end
Old 08-10-2023, 08:52 AM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
If you want to be correct as built by Henry, Terry, Oh has it correct, and all of my original '35 Ford's are just as he described.
Even though all the threaded studs have cotter pin holes (for standardization in manufacturing), if you've ever tried removing cotter pins and castle/slotted nuts, that someone unknowingly placed at those two bottom locations, you will immediately understand why Ford did not do that
John
Old 08-10-2023, 10:32 AM   #4
petehoovie
petehoovie's Avatar
Old 08-10-2023, 12:22 PM   #5
JM 35 Sedan
This picture shows the rear transmisson mount upside-down. The holes for mounting the emergency brake handle should be on the right side of the transmission as you sit in the left hand drivers seat, at least for cars built in the USA.
John
Old 08-10-2023, 04:23 PM   #6
4 MAINS V8
4 MAINS V8's Avatar
Agreed the mounting is upside-down. For reference RHD English built 35/36s handbrake is also mounted on the right hand side.
4 MAINS V8 is offline   Reply With Quote
Old 08-10-2023, 04:43 PM   #7
petehoovie
petehoovie's Avatar
Old 08-11-2023, 11:46 AM   #8
JM 35 Sedan
Yes indeed, and hopefully the OP, mmumley, came back to read these responses made on his post, and understands what is necessary to correctly install the drive train in his '36.
John
Old 08-13-2023, 01:32 PM   #9
mmumley
Thanks for pointing out that it was upside down. It just returned from being repaired at a transmission shop. I would have eventually discovered this but definitely saves me a bunch of time and aggravation.
Old 08-13-2023, 06:49 PM   #10
DavidG
DavidG's Avatar
Castle nuts were phased out progressively for most applications in the U.S. in favor of slotted hex nuts, including for the subject application, as a cost saving starting in th '33 model year.
