08-08-2023, 10:34 AM | #1 |
Rebuilding a '51 226 H fuel pump
I have a '47 tonner with a '51 226 H and am running it on an electric pump, but I really prefer a mechanical pump. I have the original mechanical which is leaky. In searching for a kit I find this one at Ecklers which states it is also for the V8. Does that sound correct? Also I have never rebuilt a fuel pump. Is it quite straightforward? I know I can send mine out, but have been in penny pinching mode lately. Does this newfound interchangeability suggest I can buy a V8 pump kit anywhere and it will work? Thanks in advance.
https://www.ecklers.com/fuel-pump-re...ogle&utm_term=
08-08-2023, 10:53 AM | #2 |
Re: Rebuilding a '51 226 H fuel pump
08-08-2023, 11:08 AM | #3 |
Yes^^^^
I dig coal, which provides motivation for EVs. |
08-08-2023, 11:10 AM | #4 |
X3 on Then and now. They make their own valves, very nice product
08-08-2023, 11:23 AM | #5 |
Wow! Probably well close to a hundred bucks with tax and shipping. At that price, I'd check with Charlie Scwhendler before I jumped in myself.
08-08-2023, 12:18 PM | #6 |
08-08-2023, 03:15 PM | #7 |
Gary.....check with Daytona Parts. https://daytonaparts.com/ 386-427-7108.
Mon-Thur. 7am-6pm EST. I’m pretty sure Charlie uses these kits........Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
08-09-2023, 12:10 AM | #8 |
I didn't see this post as I got delayed while typing out my next... Thanks!
08-09-2023, 12:19 AM | #9 | |
08-09-2023, 04:06 AM | #10 |
I’ve never had to find parts for the 226, but 12 years ago I bought a pump from Ecklers for my ‘50 it lasted one year. I got one at my local NAPA and it still works fine. Suppliers parts change but I think I would find something from a different vender…….Mark
08-09-2023, 06:44 AM | #11 |
A leaking pump....where is it leaking from. A rebuild kit may not be able to fix a leak depending upon where the leak is.
08-09-2023, 10:16 AM | #12 |
I can't remember where it was leaking from. I will look very carefully for cracks and check surfaces for flat at rebuild time.
08-09-2023, 04:38 PM | #13 |
Could also check with cowboy John. Much praised on FTE for a kit. No sense sending off carbs and fuel pumps to be rebuilt.
08-09-2023, 08:11 PM | #14 |
Thanks. Lots of youtube videos on the subject. Looks pretty simple. I tried calling a guy in Upstate NY who lists ethanol resistant USA made kits. His recording said something about taking time off. I found a new pump in an airtex box on my shelf. It had a glass bowl and was V8 style. On the barcode I see a date of 2015 so it isn't ancient. Says 1951-1953 V8. I think it came in a box of parts I came across. Half tempted to see if the parts really interchange as I have a recent pump on the woodie and that's my only V8. Anybody confirm the guts are the same?
08-09-2023, 08:27 PM | #15 |
I have learned to lap the split line surfaces on fuel pumps when I put a kit in. You will be surprised at how far from flat the surfaces are. I wet sand with the paper on a very flat surface (I'm lucky to have access to a surface plate my friend has).
08-09-2023, 08:35 PM | #16 |
I have a 6" wide belt sander with a 3' platen I use for manifolds, but small stuff I use stick on sandpaper on the 1950's Delta jointer, so that is something I will do.
08-09-2023, 09:52 PM | #17 |
Original pumps, at least the late V8 AC pumps, had a little “bridge” holding valves into housing. I have seen replacement pumps with valves pressed in. Can’t mix the two. Not sure if airtex have pressed in valves. Be worth a look to see if valves and diaphragm interchange
08-09-2023, 10:01 PM | #18 |
A WW2 Jeep pump with hand primer and WW2 IHC M-2-4 pump I restored with Then and Now kits. Bodies I chromated and replated steel parts. Kits may be expensive, but fellows I did these for had no complaints
08-09-2023, 10:11 PM | #19 | |
08-09-2023, 10:44 PM | #20 | |
