#1 |
1929 AA has split ring wheels which a in rough shape and need replacing. This is a stake bed AA needing restoration but before going forward would like to get upgrade wheels. In addition it is getting almost impossible to find anyone to touch them. Does anyone know of a modern type wheel that I could put on this truck? Thanks in advance.
Don Cumming Ga |
#2 |
Give me a call. 740 658 3495 I will tell you what I did.
#3 |
In case you do not know this:
Putting air into a split rim tire or removing wheels from the vehicle can kill you or seriously injure you if the rim is not installed correctly. https://www.hsa.ie/eng/safety_alerts...ponent%20parts. 50 years ago I met guy who was "airing up" an AA truck tire when the ring came off and caught him under the jaw. He lost most of his lower jaw and 1/2 of his upper teeth. THERE ARE SPECIAL TOOLS and methods to do this work safely. Last edited by Benson; 08-05-2023 at 11:26 PM. |
#4 |
Please don't be misled here. The AA wheels are NOT split rims. They are solid wheels with a retaining ring. They still have this very similar style today on new big rigs, heavy equipment, and buses here in the USA. ANY truck tire shop can assist you with this style AA wheel.
#5 |
OK spdway1 thanks,
This fellow may not have been hurt with an AA wheel but it was a heavy truck wheel of some type. So you are saying that the AA wheels are safe to "air up" with out safety measures and steel cages? |
#6 |
#7 | |
![]() Quote:
The problem lies in the process of getting them aired up and seated properly. Have a professional tire repair shop do this for you.
Dave / Lincoln Nebraska |
#8 |
Use safety measures in everything that you do, this should go without saying. Yes, use a cage to air up. Just pay a truck tire shop to do your AA tire work, and you won't regret it.
#9 |
I assembled mine (no air) and took them into a truck tire shop. They aired them up for me using a cage. When I asked them what I owed them he said for what? Air??
Nice of them to do it for free.
#10 |
I do my own tire changes on my AA truck. Wrap a chain around tire/rim, to catch anything that might want to go airborne.
#11 |
These rims are very dangerous and yes, they can kill if not handled properly. The condition of the rim and ring are very important. You must use a good sold rim/ring (can be hard to find) free of any loose rust flakes and need to be thoroughly cleaned of such material. There is a very specific process to follow in order to properly seat the rings. I would also strongly suggest having a pro with a cage do them. Rings that blow off can take your head off and that is no exaggeration. Lastly, some people add bead into the tub to help balance the tire. I did not, and mine are fine. Remember, the top speed of a stock AA truck is about 35-37 MPH so it is not necessary to do so. Good luck.
